[GRASS-user] problem with g.gui.rlisetup on windows 10
Veronica Andreo veroandreo at gmail.com
Wed May 18 06:32:38 PDT 2022
Hello Cyril,
I do not have Windows, but I made some tests in Linux and, as you said, it
works fine. So, to understand the syntax of the conf file, I clicked random
options and saved a file named bla and then I clicked over Edit/View (see
attachment). It's kinda reverse engineering, but well...
I agree that the output file should be displayed here
https://grass.osgeo.org/grass80/manuals/wxGUI.rlisetup.html. Would you mind
following that example and providing the resulting config file?
Best,
Vero
El lun, 16 may 2022 a las 11:34, Cyril BERNARD (<cyril.bernard at ird.fr>)
escribió:
> Hello everyone,
> I met a problem with g.gui.rlisetup tool on Windows.
> It is impossible to type the name of the configuration file in the
> dialog (the text zone stays blank), thus impossible to click on "Next"
> button, and to create the file.
> Meanwhile I tried on Linux, and it works. So I have to create liconf
> file on Linux and then, import it on
> C:\Users\xxx\AppData\Roaming\GRASS7\r.li ...
> What's wrong with g.gui.rlisetup tool on Windows ? Is it a bug already
> described ?
> And, where can I find a documentation about the syntax, if I want to
> create & edit the config file for r.li in a classic editor such as
> notepad ?
> Regards,
> Cyril Bernard
> UMR Espace-Dev_______________________________________________
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20220518/b0758c89/attachment-0001.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20220518/b0758c89/attachment-0001.png>
