[GRASS-user] empty results from v.distance
Ken Mankoff mankoff at gmail.com
Fri May 20 21:27:54 PDT 2022
Hello GRASS list,
I'm running v.distance because I'd like to assign the nearest area ID to a points vector. Some of the points are outside any areas.
I'm using this command:
v.distance from=points to=areas upload=to_attr column=c to_column=ID output=connections
And I'd like to see a new column "C" in the points table that contains the ID from the nearest area in areas.
If I plot points, areas, and connections, it appears that every point is connected to an area. But if I `db.select points|head`, many rows in the ID column are empty. I would not expect any to be empty. Can someone explain what I might be doing wrong?
Thank you,
  -k.
