[GRASS-user] i.histo.match
Giuseppe Amatulli
giuseppe.amatulli at gmail.com
Wed Oct 12 07:21:48 PDT 2022
Hi Markus,
thanks for your reply and sorry for my late reply.
Yes indeed I have used the GRASS GIS 8 on the docker format (at Yale
Cluster) and the i.histo.match works fine.
Thanks for pointing that out!!!
Keep in touch
Giuseppe
On Tue, 27 Sept 2022 at 15:54, Markus Neteler <neteler at osgeo.org> wrote:
> Hi Giuseppe,
> Giuseppe Amatulli <giuseppe.amatulli at gmail.com> schrieb am Di., 27. Sep.
> 2022, 15:38:
>> Dear Grass team
>> I'm trying to use the add on i.histo.match in grass 7.8.2 but something
>> is not going well.
>> GRASS 7.8.2 (tmploc):/tmp > i.histo.match
>> input=570-0000000000-0000023296.1,570-0000000000-0000023296.1
>> output=mosaic max=4000 --overwrite --verbose
>> WARNING: Bug in UI description. Missing module description
> I assume that you compiled GRASS GIS yourself?
> This error usually indicates that a clean recompilation is needed, with
> make distclean
> as the first step.
>> The warning also appears during the i.histo.match installation.
> So, first a clean GRASS compilation, then add-ons on top.
> Hope this helps,
> Markus
> PS: GRASS GIS 8 is highly recommended!
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20221012/c453e9b1/attachment.htm>
