[GRASS-user] r.terrain.geom
Maria Cecilia Zalazar zalazarmariacecilia at gmail.com
Thu Oct 27 15:37:58 PDT 2022
 data.zip
<https://drive.google.com/file/d/1IMj2GeM5QPPfix2LwvSuZ1tPonzKeW3x/view?usp=drive_web>
Dear Grass community, there is a very interesting grass add-on
(r.terrain.geom) that extracts fluvial terrace-like surfaces from digital
elevation models and also creates a pdf plot with graphs showing the
terrain characteristics and logic of process (R interface).
https://github.com/edinaj0zs4/terrace_extraction_grassgis
(Józsa, E., 2019. Geomorphometric application of quasi-global DEMs for
semi-automated geomorphological mapping. University of Pécs)
My winGrass version is 8.2 and I had to modify the TERRACE_jozsa (R-script)
in order to update the interface required package (rgrass instead
of spgrass6). Also the ggplot2 version was necessary to update. I'm sending
the new R script.
Actually, this is not an available add-on script via g.extension in oficial
repositories. I'm not sure which are the requirements to do this (some
improvements or check?), or if it is possible to make it accessible via a
public repository.
I´m sending data for easy checking.
Thanks very much in advance!
Regards!
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20221027/9950c362/attachment-0001.htm>
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20221027/9950c362/attachment-0001.html>
Type: text/x-python
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20221027/9950c362/attachment-0001.py>
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20221027/9950c362/attachment-0003.obj>
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20221027/9950c362/attachment-0004.obj>
Type: text/markdown
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20221027/9950c362/attachment-0001.md>
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20221027/9950c362/attachment-0005.obj>
