[GRASS-user] Mouse coordinates in Map Window not following GUI settings projection
Veronica Andreo veroandreo at gmail.com
Wed Aug 16 09:09:20 PDT 2023
This is what I have in GRASS 8.2.1
[image: image.png]
[image: image.png]
However, to make it work then, you need to select the preferred CRS in the
GUI main menu: Settings > Preferences > Projections
El mié, 16 ago 2023 a las 12:51, Eric Patton via grass-user (<
grass-user at lists.osgeo.org>) escribió:
> On Tue, Aug 15, 2023 at 03:11:40PM -0400, Anna Petrášová wrote:
> > On Tue, Aug 15, 2023 at 1:39 PM Eric Patton via grass-user <
> > grass-user at lists.osgeo.org> wrote:
> >     I am having trouble getting the Grass GUI map window mouse
> coordinates to
> >     display Lat-Long WGS84 coordinates in the lower-left corner of the
> display
> >     window.
> >     I checked the GUI settings Projection tab, and it is set to
> EPSG:4326,
> >     and references /usr/local/share/proj/epsg, but I can't find this file
> >     anywhere
> >     on my system.
> > I have there /usr/share/proj/epsg
> > but even if you can't find it, entering 4326 and proj string
> > +proj=longlat +datum=WGS84 +no_defs +type=crs
> > should do it. Then, you have to switch that on in map display settings
> (see map
> > display toolbar) -> Status bar -> Display coordinates in different CRS
> > The idea was to move the epsg panel in GUI settings to the map display
> > settings, but this part never got finished...
> Yes, I have this proj string in place in the Projection tab.
> I don't see any option for 'Display coordinates in different CRS' in Map
> Display -> Status Bar though. The options I have are:
> Coordinates
> Display Extent
> Computational Region
> Display Geometry
> Map Scale
> Go to XY coordinates
> Eric
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20230816/e5bfc345/attachment-0001.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20230816/e5bfc345/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20230816/e5bfc345/attachment-0003.png>
