[GRASS-user] Pipe character in text field
Maris Nartiss maris.gis at gmail.com
Mon Dec 4 08:06:02 PST 2023
If you are executing this command from a shell (e.g. bash), you must
escape or enclose in single quotes the pipe character.
Try:
v.db.update map=mymap column=xkey value='|'
Māris.
pirmd., 2023. g. 4. dec., plkst. 10:51 — lietotājs gisfisch--- via
grass-user (<grass-user at lists.osgeo.org>) rakstīja:
> Hello list,
> I have to insert a pipe character in a text field. I use:
> v.db.update map=mymap column=xkey value=|
> but that will result in ^| instead of just the pipe |
> How do I get rid of that little hook? Using a backslash to escape did not help.
> Mit freundlichen Grüßen,
> Uwe Fischer
> Ingenieurbüro Fischer
> Esbecker Str. 8
> 31036 Eime
> T. 05182/8325
> T. 0172/8876934
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
