[GRASS-user] r.sun - beam irradiance issues in mountain area with a high relief energy
Anna Petrášová kratochanna at gmail.com
Wed Feb 1 06:40:27 PST 2023
This could be potentially a problem described in
https://github.com/OSGeo/grass/pull/2534.
Could you try to run this with the changes in the PR?
Anna
On Tue, Jan 31, 2023 at 4:05 PM Helmut Kudrnovsky <hellik at web.de> wrote:
> hi,
> given a a mountain area with a high relief energy based upon an ALS DEM
> with a 1x1m resolution
> and system: winGRASS GIS 8.2.1
> g.region -p
> projection: 99 (MGI / Austria Lambert)
> zone:       0
> datum:      hermannskogel
> ellipsoid:  bessel
> north:      358599.5
> south:      345055.5
> west:       221323.5
> east:       236275.5
> nsres:      1
> ewres:      1
> rows:       13544
> cols:       14952
> cells:      202509888
> DEM range of data: min = 1197.4  max = 3496.68
> the horizon rasters are calculated by
> r.horizon elevation=als at data step=30 maxdistance=5000 output=horangle
> r.sun is calculated for 15 June
> r.sun elevation=als at data aspect=als_aspect at data slope=als_slope at data
> horizon_basename=horangle horizon_step=30 beam_rad=beam_rad166 day=166
> nprocs=2 npartitions=2
> see the result screenshot in https://pasteboard.co/YShtdFG8C7jk.png
> o the high peak has northern, eastern and southern oriented steep slopes
> o the more red, the higher beam irradiance calculated by the r.sun command
> above
> o the southern oriented footslopes show a high beam irradiance (as
> exptected)
> o the southern oriented and very steep slopes around the peak show a
> similar low beam irradiance as the northern slopes (not expected)
> I have issues to interpret the results, especially the last pattern:
> o Could be the lower beam irradiance in the very southern oriented slopes
> nearby the peak due to the very steep slope?
> o Do slopes with a high inclination (though southern oriented) reduce beam
> irradiance in the implemented model?
> Kind regards
> Helmut
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20230201/90e88ca8/attachment.htm>
