[GRASS-user] Fwd: skipping MEM driver with r.out.gdal for large files
Markus Neteler neteler at osgeo.org
Thu Jun 22 00:16:46 PDT 2023
Hi Laura,
On Thu, Jun 15, 2023 at 5:00 PM Laura Poggio <laura.poggio at gmail.com> wrote:
> Dear all,
> Apologies, sent to the developer mailing list by mistake.
> I am trying to save a rather large file from GRASS
> Versions:
> GRASS GIS 8.2.1
> GDAL 3.6.3, released 2023/03/07
> Linux: almalinux:9.1
> The size of the file is:
> rows=141120
> cols=362880
> cells=51209625600
> This the command
> r.out.gdal -c input=out output=output.tif format=COG type=Int16 createopt=COMPRESS=LZW,PREDICTOR=2,BIGTIFF=YES --overwrite --quiet
> This the output
> Warning 6: driver MEM does not support creation option COMPRESS
> Warning 6: driver MEM does not support creation option PREDICTOR
> Warning 6: driver MEM does not support creation option BIGTIFF
> ERROR 2: /usr/gdal-3.6.2/frmts/mem/memdataset.cpp, 1289: cannot allocate 1x102419251200 bytes
> ERROR: Unable to create dataset using memory raster driver
> Is there any option not to use the MEM driver when writing to disk?
I am not sure, in this code section it doesn't look like this:
https://github.com/OSGeo/grass/blob/51e962abbc1176211ad2c4cb7857a61a2b6d1c6f/raster/r.out.gdal/main.c#L377
Maybe someone else in the list has more insights?
Some options:
- try first the GTiff driver, then convert to COG with gdal_translate
- enlarge RAM using a swap file (no reboot needed but sudo access
needed) as disk space is relatively cheap and r.out.gdal will not
realize then that it gets swapped.
Best,
Markus
Markus Neteler, PhD
https://www.mundialis.de - free data with free software
https://grass.osgeo.org
https://courses.neteler.org/blog
