[GRASS-user] PDAL version issue
Maris Nartiss maris.gis at gmail.com
Fri Nov 24 09:05:25 PST 2023
Check that you also have -dev packages (if they are separate on your
Linux distro). Exact error message will be in the config.log file.
Without it it is hard to tell what went wrong as I have PDAL 2.3.0 and
it compiles fine.
Māris.
piektd., 2023. g. 24. nov., plkst. 17:21 — lietotājs Rich Shepard via
grass-user (<grass-user at lists.osgeo.org>) rakstīja:
> Installed here is pdal-2.2.0. When I configure the updated source code it
> fails at this point:
> checking whether to use PDAL... yes
> configure: error: *** Unable to locate suitable (>=1.7.1) PDAL library.
> The configuration file ends with
> --with-pdal=/usr/bin/pdal
> and pdal is found in /usr/bin/pdal
> Please suggest how I let configure know the installed pdal is >=1.7.1.
> TIA,
> Rich
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
