[GRASSweb-list]markus: web/grass51 examples.html,1.16,1.17
grass at intevation.de grass at intevation.de
Wed Dec 11 12:49:00 EST 2002
Author: markus
Update of /grassrepository/web/grass51
In directory doto:/tmp/cvs-serv19832
Modified Files:
	examples.html
Log Message:
v.db.connect
Index: examples.html
RCS file: /grassrepository/web/grass51/examples.html,v
retrieving revision 1.16
retrieving revision 1.17
diff -u -d -r1.16 -r1.17
--- examples.html	10 Dec 2002 17:51:38 -0000	1.16
+++ examples.html	11 Dec 2002 17:48:58 -0000	1.17
@@ -157,8 +157,10 @@
 #to use the new map, you should link attributes to it. This can
 #be the table from the parent map. Edit the DB file and add a row for
 #the new map (here: markveggy.1)
+#Then check connection:
+v.db.connect input=markveggy.1
-#Then, query new map:
+#Query new map with attributes:
 d.what.vect -a
 #Or you can display with labels attached to the vector: First we check
@@ -304,7 +306,7 @@
 <!-- FOOTER -->
 <p>
 <hr>
-<DIV ALIGN=right>&copy; 2002 GRASS Development Team/MN<br>
+<DIV ALIGN=right>&copy; 2002 GRASS Development Team/Markus Neteler<br>
 <a href="mailto:weblist at grass.itc.it">Comments</a> about this page | <a href="../faq/index.html">FAQ</a> | <a href="../download.html">Download</a> | <a href="../support.html">Support</a> | <a href="../gdp/index.html">Docs</a>  | <a href="../grassdevel.html">Programming</a> | Back <a href=index.html>5.1 HOME</a><br>
 <i>Last change:
 $Date$
More information about the grass-web mailing list
