[GRASSweb-list]library problem..
Markus Neteler neteler at itc.it
Mon Jul 22 09:21:29 EDT 2002
The Solaris NCURSES is available here (precompiled):
http://www.sunfreeware.com/
  http://www.sunfreeware.com/programlistsparc8.html#ncurses
Kind regards
 Markus Neteler
On Thu, Jul 18, 2002 at 11:40:22AM +0200, Bernhard Reiter wrote:
> The homepage of the ncurses library is:
> 	http://www.gnu.org/software/ncurses/ncurses.html
> GRASS can use alternative libraries, maybe your system administrator
> should advise you and help to build grass from source.
> Then it will use the libraries you already have on your system.
> Hope this helps,
> 	Bernhard Reiter
> On Thu, Jul 18, 2002 at 10:57:09AM +0530, Dr. D.S. Arya wrote:
> >    I have installed grass5 on solaris 8 successfully. But when I run the
> >    s/w it gives error that file libncurses.so.5 is not found. This file
> >    is not available with the OS. When searched over Internet, it is found
> >    a linux library file. Could you please tell me where from this file be
> >    downloded?
More information about the grass-web mailing list
