[GRASSweb-list]markus: web/grass51 examples.html,1.10,1.11 index.html,1.35,1.36
grass at intevation.de grass at intevation.de
Thu Nov 7 13:40:06 EST 2002
Author: markus
Update of /grassrepository/web/grass51
In directory doto:/tmp/cvs-serv11691/grass51
Modified Files:
	examples.html index.html
Log Message:
improved footers
Index: examples.html
RCS file: /grassrepository/web/grass51/examples.html,v
retrieving revision 1.10
retrieving revision 1.11
diff -u -d -r1.10 -r1.11
--- examples.html	5 Nov 2002 16:33:29 -0000	1.10
+++ examples.html	7 Nov 2002 18:40:04 -0000	1.11
@@ -7,9 +7,8 @@
 </head>
 <body text="#000000" bgcolor="#FFFFFF" link="#0000EF" vlink="#59188E" alink="#FF0000">
-<font face="Arial, Helvetica">
 <table width="100%" cellpadding="3" border="0">
-<tr><td align="left" bgcolor="#10ef40"><font color="#00000" face="Helvetica"><big><b>
+<tr><td align="left" bgcolor="#B0F0B0"><font color="#00000"><big><b>
 GRASS 5.1 Usage Examples
 </b></big></font></td></tr></table><p>
@@ -21,7 +20,7 @@
 <i><b>Disclaimer:</b> These examples described here may work or
         not. You are kindly invited to send us further examples and/or
-        code bugfixes/enhancements.<i>
+        code bugfixes/enhancements.</i>
 <P>
 To get debug information, set variable (set to 0 for debug silence) to
@@ -40,7 +39,7 @@
 <li>g.gisenv   g.mapsets  g.region
 <li>nviz
 <li>v.build v.clean.test  v.in.ascii  v.rand.poly
-    v.topo.check v.build.polylines v.convert v.info v.shape.register v.to.rast
+    v.topo.check v.build.polylines v.convert v.info v.shape.register
     v.category v.digit v.out.ascii v.shape.unregister v.clean v.extract
     v.out.ogr v.surf.rst
 </ul>
@@ -70,7 +69,7 @@
 </font>
 <p><table width="100%" cellpadding="3" border="0">
 Example 1: Convert 5.0 vector maps to 5.1
@@ -85,7 +84,7 @@
 so you can use the  same names.
 <big><b>
 Example 2: Export of 5.1 vector map to GRASS 5.0
@@ -97,7 +96,7 @@
 Then go to 5.0 and run v.in.ascii + v.support.
 Example 3: Registration of a map in SHAPE format
@@ -144,7 +143,7 @@
 Example 2: Extract vector data from map to new map with SQL statements
@@ -156,7 +155,7 @@
 </pre>
 Example 4: Export data using OGR
@@ -173,7 +172,7 @@
 Example 5: Conversion of SHAPE map to GRASS 5.1 vector map
@@ -222,7 +221,7 @@
 </pre>
 Example 6: Connecting GRASS 5.1 DBMI (attributes) to PostgreSQL
       through ODBC
@@ -335,7 +334,7 @@
 Example 7: Export of SHAPE-DBF file to PostgreSQL and vector map
       link to PostgreSQL through ODBC
@@ -358,7 +357,7 @@
 Example 8: SQL queries
@@ -421,7 +420,7 @@
 <p>
 <hr>
 <DIV ALIGN=right>&copy; 2002 GRASS Development Team/MN<br>
-<a href="mailto:weblist at grass.itc.it">Comments</a> about this page | Back <a href=index.html>5.1 HOME</a><br>
+<a href="mailto:weblist at grass.itc.it">Comments</a> about this page | <a href="faq/index.html">FAQ</a> | <a href="download.html">Download</a> | <a href="support.html">Support</a> | <a href="gdp/index.html">Docs</a>  | <a href="grassdevel.html">Programming</a> | Back <a href=index.html>5.1 HOME</a><br>
 <i>Last change:
 $Date$
 </i></DIV>
Index: index.html
RCS file: /grassrepository/web/grass51/index.html,v
retrieving revision 1.35
retrieving revision 1.36
diff -u -d -r1.35 -r1.36
--- index.html	5 Nov 2002 15:37:57 -0000	1.35
+++ index.html	7 Nov 2002 18:40:04 -0000	1.36
@@ -177,7 +177,7 @@
 <!-- FOOTER -->
 <hr>
 <DIV ALIGN=right>&copy; 1999-2002 GRASS Development Team<br>
-<a href="mailto:weblist at grass.itc.it">Comments</a> about this page | Back <a href=../index2.html>HOME</a><br>
+<a href="mailto:weblist at grass.itc.it">Comments</a> about this page | <a href="faq/index.html">FAQ</a> | <a href="download.html">Download</a> | <a href="support.html">Support</a> | <a href="gdp/index.html">Docs</a>  | <a href="grassdevel.html">Programming</a> | Back <a href=../index2.html>HOME</a><br>
 <i>Last change:
 $Date$
 </i></DIV>
More information about the grass-web mailing list
