[GRASSweb-list]markus: web/sqlgrass odbc_grass_install.html,1.7,1.8
grass at intevation.de grass at intevation.de
Sat Nov 9 19:37:05 EST 2002
Author: markus
Update of /grassrepository/web/sqlgrass
In directory doto:/tmp/cvs-serv29775/sqlgrass
Modified Files:
Log Message:
updated to CSS. Removed tons of font parameters
Index: odbc_grass_install.html
RCS file: /grassrepository/web/sqlgrass/odbc_grass_install.html,v
retrieving revision 1.7
retrieving revision 1.8
diff -u -d -r1.7 -r1.8
--- odbc_grass_install.html	30 Oct 2002 11:14:17 -0000	1.7
+++ odbc_grass_install.html	10 Nov 2002 00:37:02 -0000	1.8
@@ -4,16 +4,18 @@
    <DEFANGED_meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
    <DEFANGED_meta name="description" content="GRASS GIS (Geographic Resources         Analysis Support System) is an open source, free Geographical         Information System (GIS) with raster, topological vector, image         processing, and visualization functionality">
    <DEFANGED_meta name="keywords" content="gis, GIS, GRASS, open source, free,         Geographical Information System, raster, topology, vector, image         processing, visualization">
-   <DEFANGED_meta name="GENERATOR" content="Mozilla/4.77 [en] (X11; U; Linux 2.4.9-6smp i686) [Netscape]">
+   <DEFANGED_meta name="Author" content="GRASS Development Team">
+   <DEFANGED_link rel="stylesheet" type="text/css" href="../sitestyle.css">
    <title>ODBC-GRASS Installation</title>
 </head>
-<body text="#000000" bgcolor="#FFFFFF">
+<body>
+<h2>ODBC-GRASS 5.0 Installation</h2>
-<h2>
-ODBC-GRASS Installation</h2>
 [related page <a href="../sqlgrasslist.html">GRASS GIS and SQL support
 with mailing list</a>]
-<p>Draft installation instructions to connect GRASS to an external DBMS
+<p>Draft installation instructions to connect GRASS 5.0 to an external DBMS
 through ODBC. Please help us to improve the instructions.
 <p>
 <hr><i>Note for PostgreSQL/ODBC users:</i>
@@ -23,10 +25,10 @@
 from unixODBC is working properly. (see psqlODBC home page:</i>
 <br><i><a href="http://odbc.postgresql.org/psqlodbc.php?DocID=faq-general">http://odbc.postgresql.org/psqlodbc.php?DocID=faq-general</a></i>
 <hr>
-<p>ODBC-GRASS Installation
+<p>ODBC-GRASS 5.0 Installation
 <ol>
 <li>
-Communication between Grass and database: Grass module &lt;-> Grass-to-ODBC-driver
+Communication between GRASS 5.0 and database: GRASS module &lt;-> GRASS-to-ODBC-driver
 &lt;-> ODBC &lt;--> ODBC-to-database -driver &lt;-> Database</li>
 <br>&nbsp;
@@ -35,7 +37,7 @@
 your favourite database (Oracle, PostgreSQL, MySQL, ...) and ODBC driver
 for the database you have chosen. However it is not necessary we recommend
 to install GUI configuration tools for ODBC: ODBCConfig and DataManager
-(unixODBC-kde rpm in RH distribution). Finaly you need Grass-to-odbc-driver.
+(unixODBC-kde rpm in RH distribution). Finaly you need GRASS-to-odbc-driver.
 Check if this driver exists: $GISBASE/driver/odbc. If this driver is not
 available you must compile grass/src/libes/dbmi/drivers/odbc/ (<a href="../download.html">GRASS
 source code</a>).</li>
More information about the grass-web mailing list
