[GRASSweb-list]markus: web grassdevel.html,1.22,1.23
grass at intevation.de grass at intevation.de
Mon Oct 28 04:48:44 EST 2002
Author: markus
Update of /grassrepository/web
In directory doto:/tmp/cvs-serv2661
Modified Files:
	grassdevel.html
Log Message:
added HTML progman
Index: grassdevel.html
RCS file: /grassrepository/web/grassdevel.html,v
retrieving revision 1.22
retrieving revision 1.23
diff -u -d -r1.22 -r1.23
--- grassdevel.html	28 Oct 2002 08:38:44 -0000	1.22
+++ grassdevel.html	28 Oct 2002 09:48:41 -0000	1.23
@@ -112,10 +112,10 @@
 <a name=prog></a>
 <h3>Related documents - GRASS 5 Programmer's Manual</h3>
 <ul>
-<li><a href=grass5/progmangrass50.pdf>GRASS
-5 Programmer's Manual</a> (PDF, 2.3 MB, updated version 4/2002) - <b>NOTE:</b>
-This (still) is a draft version under development! Get updated versions regularly
-from here.
+<li>GRASS 5.0 Programmer's Manual [ <a href=grass5/progmangrass50.pdf>PDF</a>,
+2.3 MB, updated version 4/2002 | <a href=http://mpa.itc.it/markus/grass50/>HTML</a> ]
+- <b>NOTE:</b> This (still) is a draft version under development! Check back
+here regularly.
 <br>You can also access the latest Latex sources of the "GRASS 5 Programmer's
 Manual" from our <a href=grasscvs.html>CVS server</a>:<br>
More information about the grass-web mailing list
