[GRASSweb-list]the excitement of http://grass.cis.sinica.edu.tw/grass51/
Dan Jacobson jidanni at dman.ddts.net
Tue Oct 29 20:08:53 EST 2002
>>>>> "M" == Markus Neteler <neteler at itc.it> writes:
M> On Sun, Oct 27, 2002 at 04:37:26PM +0800, Dan Jacobson wrote:
>> Regarding all the excitement of
>> Contrast it with the INSTALL file once we download the code:
>> The GRASS 5.1 code repository currently contains only the new
>> 3D/DBMS vector library and a few rewritten vector modules.
>> Well, http://grass.cis.sinica.edu.tw/grass51/ should mention that.
M> It does:
M> "GRASS 5.1 project has been started. The current implementation covers the
M> new 3D multiattribute, multilayer vector library, a modified NVIZ and a few
M> database management tools."
M> Or not?
problem one, the items mentioned are not all the same.
problem two,  http://grass.cis.sinica.edu.tw/grass51/ should say
"Only download 5.1 if you intend to use X, Y, Q... otherwise there is
no need to upgrade from 5.0" or something like that.
More information about the grass-web mailing list
