[GRASSweb-list]markus: web grasscvstags.html,1.6,1.7
grass at intevation.de grass at intevation.de
Sun Sep 22 20:33:19 EDT 2002
Author: markus
Update of /grassrepository/web
In directory doto:/tmp/cvs-serv12612
Modified Files:
	grasscvstags.html
Log Message:
fixed branches and tags
Index: grasscvstags.html
RCS file: /grassrepository/web/grasscvstags.html,v
retrieving revision 1.6
retrieving revision 1.7
diff -u -d -r1.6 -r1.7
--- grasscvstags.html	25 Jun 2002 15:43:27 -0000	1.6
+++ grasscvstags.html	23 Sep 2002 00:33:17 -0000	1.7
@@ -12,9 +12,7 @@
 Most of the time, GRASS development occurs at the head of the CVS
 tree. When the code becomes sufficiently stable that it could be
 considered a candidate for release, a branch is created in CVS. This
-branch may be checked out using the appropriate CVS tag. For example,
-on 26 April 2002, the GRASS 5.0.0 branch was created with a tag name
-of "releasebranch_26_april_2002_5_0_0".
+branch may be checked out using the appropriate CVS tag.
 <p>
 When the branch is created the release is considered "frozen". That
@@ -46,26 +44,28 @@
 <table BORDER BGCOLOR="#FFFFCC" NOSAVE >
 <tr NOSAVE>
 <td NOSAVE><font face="Arial, Helvetica"><font size=+0>To check out the
-lastest code within the release branch into a fresh directory,
-enter:&nbsp;</font></font>
+lastest unstable code into a fresh directory, enter:&nbsp;</font></font>
 <br><font face="Arial, Helvetica"><font size=+0>&nbsp;
-    cvs -z3 checkout -r releasebranch_26_april_2002_5_0_0 grass
+    cvs -z3 checkout grass
 </font></font>
 </td></tr>
 <tr NOSAVE>
 To update your existing <b>experimental</b> CVS tree to the <b>stable release
 branch</b> instead of downloading a full copy, enter:<br>
-&nbsp;&nbsp;cvs update -r releasebranch_26_april_2002_5_0_0<br>
-&nbsp;&nbsp;cvs up -dP
+&nbsp;&nbsp;cvs update -r <br>
+&nbsp;&nbsp;cvs up -dP release_30_08_2002_grass5_0_0
 </font></font>
 </td>
 </tr>
 </table>
 <li>
+GRASS 5.0.0: On 5 September 2002, the GRASS 5.0.0 stable was created with a tag name
+of "release_30_08_2002_grass5_0_0".
+<li>
 Below tags are ONLY used to define a specific state in GRASS development.
-If you want to get the latest GRASS 5 code, use above tag.
+If you want to get the latest stable GRASS 5 code, use above tag.
 <ul>
 <li>GRASS 5.0.0pre5: has been tagged as "release_25_06_2002_grass5_0_0_pre5"
 <li>GRASS 5.0.0pre4: has been tagged as "release_13_may_2002_grass5_0_0_pre4"
More information about the grass-web mailing list
