[GRASSweb-list]markus: web/grass51 index.html,1.64,1.65
grass at intevation.de grass at intevation.de
Tue Dec 2 11:03:40 EST 2003
Author: markus
Update of /grassrepository/web/grass51
In directory doto:/tmp/cvs-serv3328
Modified Files:
Log Message:
small fixes
Index: index.html
RCS file: /grassrepository/web/grass51/index.html,v
retrieving revision 1.64
retrieving revision 1.65
diff -u -d -r1.64 -r1.65
--- index.html	21 Oct 2003 08:43:20 -0000	1.64
+++ index.html	2 Dec 2003 16:03:37 -0000	1.65
@@ -111,7 +111,7 @@
 </ul>
 </ul>
-The 5.7 code (still) requires the experimental tree of GRASS 5.0 code to
+The 5.7 code (still) requires the experimental tree of GRASS 5.3 code to
 compile (note: the preX release won't work!) as it will be partly merged
 into the 5.7 directory structure during compilation. From time to time more
 code will be migrated into 5.7.
@@ -169,7 +169,7 @@
 <ul>
 <li>
 Download <a href="source/snapshot/">CVS snapshot</a> (Note: compilation of
-GRASS 5.7 requires <a href=../grass5/source/snapshot_experimental/>GRASS 5.0 experimental (CVS HEAD) source code</a>!)
+GRASS 5.7 requires <a href=../grass5/source/snapshot_experimental/>GRASS 5.3 experimental (CVS HEAD) source code</a>!)
 </li>
 <li>
@@ -189,7 +189,7 @@
 cvs -z3 co grass</li>
 <br>The latter is the experimental GRASS
-5.0 code which is needed (this code is partly linked into GRASS 5.7)</ul>
+5.3 code which is needed (this code is partly linked into GRASS 5.7)</ul>
 <li>
More information about the grass-web mailing list
