[GRASSweb-list]markus: web/grass51/tutorial examples.html,1.19,1.20
grass at intevation.de grass at intevation.de
Thu Feb 27 16:53:00 EST 2003
Author: markus
Update of /grassrepository/web/grass51/tutorial
In directory doto:/tmp/cvs-serv32306
Modified Files:
	examples.html
Log Message:
new network tools arrived
Index: examples.html
RCS file: /grassrepository/web/grass51/tutorial/examples.html,v
retrieving revision 1.19
retrieving revision 1.20
diff -u -d -r1.19 -r1.20
--- examples.html	20 Feb 2003 16:42:14 -0000	1.19
+++ examples.html	27 Feb 2003 21:52:58 -0000	1.20
@@ -48,12 +48,18 @@
 <li>g.copy g.gisenv g.list g.mapsets g.region g.remove g.rename
 <li>nviz
 <li>r.buffer  r.clump  r.colors  r.composite  r.cost  r.his  r.mapcalc
-    (the same as in 5.0.x)
-<li>v.build v.build.polylines v.category v.clean v.convert v.database
-v.db.connect v.digit v.extract v.format v.in.ascii v.info v.in.ogr v.in.sites
-v.net.alloc
-v.out.ascii v.out.ogr v.patch v.surf.rst v.topo.check v.to.rast v.transform
+    (the same as in 5.0.x). Use 'make binmix' to link most other compiled
+    5.0 modules into 5.1.
+<li>Vector:
+<ul>
+ <li>Topology/Geometry: v.build v.build.polylines v.clean v.format
+ <li>Attributes: v.category v.database v.db.connect
+ <li>Map generating: v.digit v.extract v.patch v.surf.rst
+ <li>Import/Export: v.in.ascii v.convert v.in.ogr v.in.sites
+      v.out.ascii v.out.ogr
+ <li>Networking: v.net.iso v.net.alloc
+ <li>Misc: v.info v.to.rast v.transform
+</ul>
 <li>
 If you start a module just by name, a related <a
  href=http://mpa.itc.it/radim/g51/d.vect-gui.jpg>GUI window pops up</a>.
More information about the grass-web mailing list
