[GRASSweb-list]markus: web/grass5 index.html,1.26,1.27
grass at intevation.de grass at intevation.de
Wed Jul 30 05:30:09 EDT 2003
Author: markus
Update of /grassrepository/web/grass5
In directory doto:/tmp/cvs-serv1932/grass5
Modified Files:
Log Message:
added suggestions from Hamish
Index: index.html
RCS file: /grassrepository/web/grass5/index.html,v
retrieving revision 1.26
retrieving revision 1.27
diff -u -d -r1.26 -r1.27
--- index.html	11 Apr 2003 07:35:33 -0000	1.26
+++ index.html	30 Jul 2003 09:30:06 -0000	1.27
@@ -97,16 +97,15 @@
 options to parallelize GRASS:
 <ul>
-<li><a href=http://www.mosix.org/>MOSIX</a>: To run in a MOSIX cluster,
+<li><a href=http://openmosix.sourceforge.net/>openMOSIX</a>: To run GRASS
+on an openMOSIX cluster,
 there is no need to modify GRASS or to link with any library, or even
-to assign processes to different nodes. MOSIX does it automatically!
-However, this only helps if you want to run several modules in parallel.
-Individual modules will be run serially on one CPU. So this is more
+to assign processes to different nodes. You can run GRASS in parallel
+sessions (same location, different mapsets) which will be sent to the
+various cluster nodes.
+However, individual modules will be run serially on one CPU. So this is more
 load-balancing than a real cluster. It should be quite easy to set up.
-<li><a href=http://openmosix.sourceforge.net/>openMOSIX</a>: There is also
-openMOSIX.
-<li><a
-href=http://www.beowulf.org>Beowulf Cluster</a>: Requires GRASS
+<li><a href=http://www.beowulf.org>Beowulf Cluster</a>: Requires GRASS
 modifications not done yet.
 <li>GRASS 5 contains the "gmath" library which contains wrapper functions to
 the numerical libraries <a
More information about the grass-web mailing list
