[GRASSweb-list]markus: web grass_addons.html,1.39,1.40 index.html,1.58,1.59 related_projects.html,1.20,1.21
grass at intevation.de grass at intevation.de
Wed Jul 30 10:12:44 EDT 2003
Author: markus
Update of /grassrepository/web
In directory doto:/tmp/cvs-serv7629
Modified Files:
	grass_addons.html index.html related_projects.html
Log Message:
more cosmetics
Index: grass_addons.html
RCS file: /grassrepository/web/grass_addons.html,v
retrieving revision 1.39
retrieving revision 1.40
diff -u -d -r1.39 -r1.40
--- grass_addons.html	1 Jul 2003 09:10:08 -0000	1.39
+++ grass_addons.html	30 Jul 2003 14:12:41 -0000	1.40
@@ -41,6 +41,9 @@
 system from within the Qt GUI framework to create applications needing GIS
 functionality. (C. Madsen, Navicon, Denmark)</li>
 <li>
+<a href="http://mpa.itc.it/radim/qgis/">QGIS & GRASS</a>: GRASS extension of
+Quantum GIS (QGIS)</li>
+<li>
 <a href="http://motivation.ru/src/">Russian TclTkGRASS</a>: translated menu system (Alex
 Shevlakov, Russia)</li>
 <li>
@@ -48,7 +51,8 @@
 href="http://wgug.meteo.uni.wroc.pl/materialy/tcltkgrass.tar.gz">Polish TclTkGRASS
 (GRASS 4.3)</a>: translated menu system (Pawel Netzel, Poland)</li>
 <li>
-<a href="http://freegis.org/cgi-bin/viewcvs.cgi/grass/src.garden/grass.java/">
+<a
+href="http://freegis.org/cgi-bin/viewcvs.cgi/grass/src.garden/grass.java/">
 GRASS-JNI</a> allows programmers to access
 GRASS data from their applications written in Java (Alexandre Sorokine,
 Japan). It was written for GRASS 4.x and awaits an update to GRASS 5.x.
Index: index.html
RCS file: /grassrepository/web/index.html,v
retrieving revision 1.58
retrieving revision 1.59
diff -u -d -r1.58 -r1.59
--- index.html	30 Jul 2003 09:30:06 -0000	1.58
+++ index.html	30 Jul 2003 14:12:41 -0000	1.59
@@ -98,10 +98,10 @@
 	<b>Programming</b><br />
 	&nbsp;&nbsp; <a href="grassdevel.html">Programming</a><br>
-	&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; - <a href="grass5/index.html">GRASS 5.0.x</a> [stable]<br>
-	&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; - <a href="grass51/index.html">GRASS 5.1.x</a> [exp]<br>
-	&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; - <a href="announces/4.3release.info.html">GRASS 4.3</a> [old]<br>
-	&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; - <a href="grassgui.html">GUIs</a><br>
+	&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; > <a href="grass5/index.html">GRASS 5.0.x</a> [stable]<br>
+	&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; > <a href="grass51/index.html">GRASS 5.1.x</a> [exp]<br>
+	&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; > <a href="announces/4.3release.info.html">GRASS 4.3</a> [old]<br>
+	&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; > <a href="grassgui.html">GUIs</a><br>
 	&nbsp;&nbsp; <a href="grassdevel.html#submission">Code submission</a> | <a href="grasscvs.html">CVS</a><br>
 	&nbsp;&nbsp; <a href="bugtracking/bugreport.html">Bug</a> | <a href="bugtracking/wish.html">Wish</a> reports<br>
 	<p />
Index: related_projects.html
RCS file: /grassrepository/web/related_projects.html,v
retrieving revision 1.20
retrieving revision 1.21
diff -u -d -r1.20 -r1.21
--- related_projects.html	22 Jul 2003 21:36:38 -0000	1.20
+++ related_projects.html	30 Jul 2003 14:12:41 -0000	1.21
@@ -22,9 +22,8 @@
 <h2>Libraries</h2>
 <ul>
-<li><a href=http://www.remotesensing.org/proj/>PROJ 4</a>: Projection/datum support
-  library. It also provides the 'cs2cs' software which reprojects x,y [,z]
-  coordinate lists including datum transformation.
+<li>GRASS:
+<ul>
 <li><a href=http://gdal.velocet.ca/projects/grass/>libgrass</a>: Standalone GRASS
       5 I/O Library to directly read/write GRASS Databases.
      <br>The latest libgrass source is also available by anonymous CVS:
@@ -40,15 +39,21 @@
     directly.<br>
     Visit the <a href=http://grass.itc.it/start.html>GRASS/MapServer Demo
     site</a>!
+<li><a href=http://mpa.itc.it/radim/grass++/index.html>GRASS++</a>
+  GRASS++ is experimental C++ open source library, which may be used in C++
+  programs, to access GRASS data.
+</ul>
+<li><a href=http://www.remotesensing.org/proj/>PROJ 4</a>: Projection/datum support
+  library. It also provides the 'cs2cs' software which reprojects x,y [,z]
+  coordinate lists including datum transformation.
 <li><a href=http://www.remotesensing.org/gdal/>GDAL</a>: Geospatial Data
      Abstraction Library (raster)
-<li><a href=http://gdal.velocet.ca/projects/osvecdb/>OSVecDB</a>: OpenSource
-     Vector Database development project
 <li><a href=http://gdal.velocet.ca/projects/opengis/>OGR</a>: OGR Simple Features Library
      (vector)
 <li><a href=http://gdal.velocet.ca/projects/shapelib/index.html>Shapelib</a>: ArcView Shapelib
 <li><a href=http://pweb.jps.net/~egm2/grass/xml/>GRASS XML pages</a> for
-<a href=http://www.w3.org/XML/>XML</a> (Extensible Markup Language) support
+ <a href=http://www.w3.org/XML/>XML</a> (Extensible Markup Language) support
 </ul>
 <a name="other"></a>
More information about the grass-web mailing list
