[GRASSweb-list]markus: web data.html,1.27,1.28
grass at intevation.de grass at intevation.de
Mon May 12 03:22:53 EDT 2003
Author: markus
Update of /grassrepository/web
In directory doto:/tmp/cvs-serv27461
Modified Files:
	data.html
Log Message:
while Spearfish is Clarke66 ellipsoid, NAD27 conus, the newer related data are in WGS84
Index: data.html
RCS file: /grassrepository/web/data.html,v
retrieving revision 1.27
retrieving revision 1.28
diff -u -d -r1.27 -r1.28
--- data.html	9 May 2003 08:25:22 -0000	1.27
+++ data.html	12 May 2003 07:22:50 -0000	1.28
@@ -32,7 +32,7 @@
  <b>GRASS 5.0.x</b>: <a href="sampledata/spearfish_grass50data.tar.gz">SPEARFISH
  data set</a> (9.7MB size) - contains raster, vector and point data of South
  Dakota [fixed some roads vector types and soils topology 2/2003]
- (UTM projection)</li>
+ (UTM projection, Clarke66 ellipsoid, NAD27 conus)</li>
 <li><b>Spearfish related Documents</b>
@@ -61,12 +61,12 @@
 <ul>
 <li> <a href="http://www.sdgs.usd.edu/register/index.html">Related
  South Dakota data from SDGS</a> (select Lawrence County, then quadrangles
- "Spearfish" and Deadwood North", needs registration)</li>
+ "Spearfish" and Deadwood North", needs registration, data in WGS84)</li>
 <li>
 <a href="http://www.gisdatadepot.com/catalog/US/61050/326/index.html">Related
-South Dakota data from GIS Datadepot</a> (Digital Orthophotos (DOQQ) - 1
-Meter, vector data etc.)</li>
+South Dakota data from GIS Datadepot</a> (e.g. Digital Orthophotos (DOQQ) at 1
+meter, vector data etc, data in WGS84)</li>
 <li>
 <a href="ftp://ftp.glcf.umiacs.umd.edu/glcf/Landsat/WRS2/p033/r029/">Related
More information about the grass-web mailing list
