[GRASSweb-list]markus: web grassdevel.html,1.36,1.37
grass at intevation.de grass at intevation.de
Mon May 26 07:44:41 EDT 2003
Author: markus
Update of /grassrepository/web
In directory doto:/tmp/cvs-serv22284
Modified Files:
	grassdevel.html
Log Message:
url fixed
Index: grassdevel.html
RCS file: /grassrepository/web/grassdevel.html,v
retrieving revision 1.36
retrieving revision 1.37
diff -u -d -r1.36 -r1.37
--- grassdevel.html	24 Jan 2003 14:51:20 -0000	1.36
+++ grassdevel.html	26 May 2003 11:44:39 -0000	1.37
@@ -154,8 +154,8 @@
 <li><b>GRASS 5.0:</b>
 <ul>
   <li>GRASS 5.0 Programmer's Manual [ <a
-   href=grass5/progmangrass50.pdf>PDF</a>, 2.3 MB, updated version 4/2002 |
-   <a href=http://mpa.itc.it/markus/grass50/>HTML</a> ]
+   href=grass5/progmangrass50.pdf>PDF</a>, 2.3 MB |
+   <a href=http://mpa.itc.it/markus/grass50progman/>HTML</a> ]
    <br>You can also access the latest Latex sources of the "GRASS 5.0
    Programmer's Manual" from our <a href="grasscvs.html#progman">CVS server</a>.
   <li> <a href=demos/r.example.tar.gz>r.example: example C code for GRASS 5
More information about the grass-web mailing list
