[GRASSweb-list]markus: web/grass51/source/snapshot README.html,1.7,1.8
grass at intevation.de grass at intevation.de
Fri Sep 12 04:05:11 EDT 2003
Author: markus
Update of /grassrepository/web/grass51/source/snapshot
In directory doto:/tmp/cvs-serv30935/grass51/source/snapshot
Modified Files:
	README.html
Log Message:
more 5.1 -> 5.7
Index: README.html
RCS file: /grassrepository/web/grass51/source/snapshot/README.html,v
retrieving revision 1.7
retrieving revision 1.8
diff -u -d -r1.7 -r1.8
--- README.html	27 Nov 2002 09:05:10 -0000	1.7
+++ README.html	12 Sep 2003 08:05:09 -0000	1.8
@@ -1,26 +1,26 @@
 <!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
 <html>
 <head>
-<title>GRASS GIS 5.1 CVS snapshot</title>
+<title>GRASS GIS 5.7 CVS snapshot</title>
 </head>
 <body bgcolor="#FFFFFF">
-<h2>GRASS GIS 5.1 CVS snapshot</h2>
+<h2>GRASS GIS 5.7 CVS snapshot</h2>
-This directory contains the weekly generated CVS snapshot of GRASS 5.1.
+This directory contains the weekly generated CVS snapshot of GRASS 5.7.
 <p>
 <b>What's that?</b><p>
-[this is highly experimental and incomplete - 5.1 needs 5.0 to compile]<p>
+[this is highly experimental and incomplete - 5.7 needs 5.0 to compile]<p>
 If you are not interested to use the CVS program for directly accessing the
-latest GRASS 5.1 source code, you can follow ongoing development by download a
+latest GRASS 5.7 source code, you can follow ongoing development by download a
 source code from this directory. This CVS snapshot is the source code checked
 out from CVS repository once a week.
 <p>
 If you are interested in daily snapshots, please access the
-<a href=../../../grasscvs.html>CVS server</a> for latest GRASS 5.1 sources
+<a href=../../../grasscvs.html>CVS server</a> for latest GRASS 5.7 sources
 directly.
 <h2>Is this snapshot stable?</h2>
@@ -30,7 +30,7 @@
 <p>
 Note: The code requires the GRASS 5.0 source code to compile as selected
 files will be automatically linked into the new code. This may change in
-future when the GRASS 5.1 repository is extended with further libraries,
+future when the GRASS 5.7 repository is extended with further libraries,
 raster modules etc.
 <h2>Installation</h2>
More information about the grass-web mailing list
