[GRASSweb-list]paul: web/grass53/source README.html,1.1,1.2
grass at intevation.de grass at intevation.de
Thu May 20 04:57:59 EDT 2004
Author: paul
Update of /grassrepository/web/grass53/source
In directory doto:/tmp/cvs-serv17691
Modified Files:
	README.html
Log Message:
Very minor updates. more to come
Index: README.html
RCS file: /grassrepository/web/grass53/source/README.html,v
retrieving revision 1.1
retrieving revision 1.2
diff -u -d -r1.1 -r1.2
--- README.html	17 May 2004 19:42:12 -0000	1.1
+++ README.html	20 May 2004 08:57:57 -0000	1.2
@@ -4,17 +4,18 @@
 This directory contains the source code for
 GRASS GIS 5.3.x in gzipped tar format.
-The large (around 19 MB) file grass5.3.x_src.tar.gz is the
+The large (around 19 MB) file grass-5.3.x.tar.gz is the
 officially released GRASS 5.3.x source code in a single file.
 Also here: weekly generated CVS snapshots
    - snapshot_experimental: experimental tree (HEAD)
    - snapshot_release: [currently not supported]
-Note: The required temporal space for a full compilation is currently 140MB
+Note: The required temporary space for a full compilation is currently 140MB
       (including object.files etc which can be removed later).
-      The resulting binary package size is between 40MB and 150MB
-      depending on your system's architecture.
+      The resulting binary package size is between 20MB and 150MB
+      depending on your system's architecture and on whether the internal
+      GRASS libraries are compiled static or shared.
 To extract do following:
@@ -45,9 +46,9 @@
 A) If you have "root" access to your machine:
-   Jump into the new directory "grass5.3.X" (change X to the current
+   Jump into the new directory "grass-5.3.X" (change X to the current
    release number):
-        cd grass5.3.X
+        cd grass-5.3.X
    Now read the INSTALL file.
    To compile enter following:
More information about the grass-web mailing list
