[GRASSweb-list]markus: web/grass50/source README.html,1.10,1.11
grass at intevation.de grass at intevation.de
Fri May 21 04:46:35 EDT 2004
Author: markus
Update of /grassrepository/web/grass50/source
In directory doto:/tmp/cvs-serv5969
Modified Files:
	README.html
Log Message:
snapshots moved to ../grass53/source/
Index: README.html
RCS file: /grassrepository/web/grass50/source/README.html,v
retrieving revision 1.10
retrieving revision 1.11
diff -u -d -r1.10 -r1.11
--- README.html	6 Nov 2003 13:58:06 -0000	1.10
+++ README.html	21 May 2004 08:46:33 -0000	1.11
@@ -7,10 +7,6 @@
 The large (around 18 MB) file grass5.0.x_src.tar.gz is the
 officially released GRASS 5.0.x source code in a single file.
-Also here: weekly generated CVS snapshots
-   - snapshot_experimental: experimental tree (HEAD)
-   - snapshot_release: [currently not supported]
 Note: The required temporal space for a full compilation is currently 340MB
       (including object.files etc which can be removed later).
       The resulting binary package size is between 60MB and 150MB
@@ -21,7 +17,7 @@
 - Create a directory for the source code:
   Example:
-        mkdir /opt/src/grass5sources
+        mkdir /opt/src/grass50sources
 - Put the package there and extract it (replace "X" with
   the current version number of GRASS 5.0.X):
More information about the grass-web mailing list
