[GRASSweb-list]markus: web/announces announce_grass530.html,1.4,1.5
grass at intevation.de grass at intevation.de
Wed May 26 04:38:57 EDT 2004
Author: markus
Update of /grassrepository/web/announces
In directory doto:/tmp/cvs-serv5322
Modified Files:
Log Message:
cosmetics, added some 'not compiled by default' (complete?)
Index: announce_grass530.html
RCS file: /grassrepository/web/announces/announce_grass530.html,v
retrieving revision 1.4
retrieving revision 1.5
diff -u -d -r1.4 -r1.5
--- announce_grass530.html	22 May 2004 19:12:36 -0000	1.4
+++ announce_grass530.html	26 May 2004 08:38:54 -0000	1.5
@@ -63,11 +63,6 @@
 to perform datum transformations, please re-run <em>g.setproj</em>, which has
 been improved.</dd>
-<dt><strong>Improved Inverse distance weighted interpolation</strong></dt>
-<dd>An improved algorithm in <em>s.surf.idw</em> indexes sites and allows greatly
-improved performance
-when the region resolution and number of sites are both very large.</dd>
 <dt><strong>Shared library support</strong><dt>
 <dd>Using the configure option --enable-gmake=no (this will become the default for
 5.4 when it is reliable on all supported platforms) makes use of a new build
@@ -94,11 +89,16 @@
 existed up to now. In addition the new module <em>d.nviz</em> allows automated
 creation of fly-through animations in nviz.</dd>
-<dt><strong>Experimental LIDAR processing tools</strong><dt>
+<dt><strong>Improved Inverse distance weighted interpolation</strong></dt>
+<dd>An improved algorithm in <em>s.surf.idw</em> indexes sites and allows greatly
+improved performance
+when the region resolution and number of sites are both very large.</dd>
+<dt><strong>Experimental LIDAR processing tools</strong> (not compiled by default)<dt>
 <dd><em>s.bspline.reg</em>, <em>s.correction</em>, <em>s.edgedetection</em>,
 <em>s.growing</em>, <em>s.to.qrast</em></dd>
-<dt><strong>Experimental hydrology and sediment transport simulation tools</strong><dt>
+<dt><strong>Experimental hydrology and sediment transport simulation tools</strong> (not compiled by default)<dt>
 <dd><em>r.sim.sediment</em>, <em>r.sim.water</em></dd>
 <dt><strong>Experimental large-scale watershed computation</strong><dt>
More information about the grass-web mailing list
