[GRASSweb-list]Re: messages from GRASSList not received
Markus Neteler neteler at itc.it
Wed May 26 05:45:07 EDT 2004
Hi David,
there is not much I can do from here (the list is administrated
at Baylor, Wako, USA).
Maybe they will help you.
Best regards
 Markus
Markus Neteler     <neteler itc it>       http://mpa.itc.it
ITC-irst -  Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18        -       38050 Povo (Trento), Italy
On Tue, May 18, 2004 at 12:43:03PM +1000, David Hine wrote:
> Hi Bruce or Moderator
> I have twice subscribed to the general list  using my e-mail address on this
> message to you.
> I get messages for several days and then the messages stop entirely.
> This may be because the domain “landandwater.com.au” is not a genuine domain
> but a virtual one (as I understand it). There may be other reasons. Could
> you kindly advise.
> thanks
> David Hine
> Land and Water Management P/L
> 29 Pacific Pde
> Mission Beach, Qld. 4852
> Ph/Fax: (07) 4088 6146
> Mobile: 0429 886 146
> E-mail: David.Hine at landandwater.com.au
> Environmental Management Systems for Agriculture
More information about the grass-web mailing list
