[GRASSweb-list]markus: web i18n.html,1.10,1.11
grass at intevation.de grass at intevation.de
Mon Nov 15 04:58:16 EST 2004
Author: markus
Update of /grassrepository/web
In directory doto:/tmp/cvs-serv23205
Modified Files:
	i18n.html
Log Message:
updated
Index: i18n.html
RCS file: /grassrepository/web/i18n.html,v
retrieving revision 1.10
retrieving revision 1.11
diff -u -d -r1.10 -r1.11
--- i18n.html	29 Oct 2004 14:24:39 -0000	1.10
+++ i18n.html	15 Nov 2004 09:58:14 -0000	1.11
@@ -20,9 +20,10 @@
 <h3>The idea</h3>
 The great interest in GRASS suggests to translate GRASS messages to
-other languages than english. Currently the "infrastructure" to
-support multibyte character sets is under development (based on
-<a href=http://www.foss4g.org/>the FOSS4G efforts</a>). Single byte character sets are already supported.
+other languages than english. The "infrastructure" to
+support single-byte as well as multi-byte character sets was implemented
+(based on <a href=http://www.foss4g.org/>the FOSS4G efforts</a>).
 <P>
 The GRASS Development Team is seeking for translators.
 Please subscribe to the dedicated mailing list at
@@ -35,7 +36,7 @@
 translation, how to merge old G5.0 translated messages into G5.7 etc).
 This is an opportunity for non-programmers to contribute as messages
-can be easily translated. No programming skills required!
+can be easily translated. <b>No programming skills required!</b><br>
 In the links section at bottom of this page you find references to the
 'kbabel' and 'poEdit' software to easily translate the message files.
@@ -47,8 +48,7 @@
 <ol>
 <li>get a fresh (!) GRASS 5.7 from <a href=http://freegis.org/grass/grass-cvs.html>CVS</a>
-    (or <a href=grass57/source/snapshot/>5.7 CVS snapshot</a> which also
-    requires the <a href=grass53/source/snapshot_experimental/>5.3 CVS snapshot</a>)
+    (or <a href=grass57/source/snapshot/>5.7 CVS snapshot</a>)
 <li>run: '<tt>cd locale</tt>'       to change into the translation directory
 <li>run: '<tt>make pot</tt>'        to create grass*.pot files (containing original messages)
 <li>run: '<tt>make update-po</tt>'  merge new messages into existing *.po files (or create new po files)
@@ -73,7 +73,7 @@
 <h3>XDRIVER TTF Support</h3>
-Recently the XDRIVER in GRASS was extended to support TTF fonts.
+Recently the XDRIVER in GRASS was extended to support True/Free Type Fonts.
 <P>
 <DEFANGED_IMG src=images/grass57_xdriver_japanese_map.png>
More information about the grass-web mailing list
