[GRASSweb-list]markus: web/devel devel.inc,1.25,1.26
grass at intevation.de grass at intevation.de
Tue Apr 18 12:31:16 EDT 2006
Author: markus
Update of /grassrepository/web/devel
In directory doto:/tmp/cvs-serv8992
Modified Files:
	devel.inc
Log Message:
explain how the Progman is generated
Index: devel.inc
RCS file: /grassrepository/web/devel/devel.inc,v
retrieving revision 1.25
retrieving revision 1.26
diff -u -d -r1.25 -r1.26
--- devel.inc	28 Mar 2006 13:41:45 -0000	1.25
+++ devel.inc	18 Apr 2006 16:31:14 -0000	1.26
@@ -122,7 +122,7 @@
  <ul>
   <li>GRASS <a href=../grass60/manuals/>6 Programmer's Manual</a>
       (PDF and packaged HTM; complete, updated weekly every Saturday)
-  <li> GRASS <a href="http://mpa.itc.it/markus/grass61progman/">6 Programmer's Manual</a> (HTML, updated regularly)
+  <li> GRASS <a href="http://mpa.itc.it/markus/grass61progman/">6 Programmer's Manual</a> (HTML, updated regularly, generated with 'make htmldocs-single')
   <li> GRASS <a href="http://mpa.itc.it/markus/grass61progman/swig/">SWIG interface</a> (HTML, updated regularly)
   <li> <a href="http://freegis.org/cgi-bin/viewcvs.cgi/grass6/doc/raster/">r.example: example C code for GRASS raster programming</a>
   <li> <a href="http://freegis.org/cgi-bin/viewcvs.cgi/grass6/doc/vector/v.example/">v.example: example C code for GRASS 6 vector programming</a>
More information about the grass-web mailing list
