[GRASSweb-list] markus: web/grass62/binary/linux/snapshot README.html, NONE, 1.1
grass at intevation.de grass at intevation.de
Sat Aug 12 14:54:13 EDT 2006
Author: markus
Update of /grassrepository/web/grass62/binary/linux/snapshot
In directory doto:/tmp/cvs-serv17505
Added Files:
	README.html
Log Message:
added
--- NEW FILE: README.html ---
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 3.2 Final//EN">
<HTML>
 <HEAD>
   <meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
   <meta name="Author" content="GRASS Development Team/MN">
   <TITLE>GRASS 6.2.cvs stable GNU/Linux binaries</TITLE>
 </HEAD>
 <BODY>
<H1>GRASS 6.2.cvs stable GNU/Linux binaries</H1>
<h2>How to install the Linux (x86/Intel) binary code for
GRASS 6.2.cvs STABLE in gzipped tar format.</h2>
<b>Note: the x86_64 binaries will only run on 64bit CPUs (use 'uname -m' to
find out about your computer).</b>
<p>
You can install and use GRASS 6 in parallel to GRASS 5.x.
<h3>Installation:</h3>
<ol>
  <li>get the file  <br>grass-6.2.cvs-ARCH-DD_MM_YYYY.tar.gz</li>
  <li>get the installation script <br> grass-6.2.cvs-ARCH-DD_MM_YYYY-install.sh</li>
</ol>
<h4>where</h4>
<ul>
  <li>ARCH is the architecture of the platform (e.g. i686-pc-linux-gnu)</li>
  <li>DD-MM-YYYY is the date of the release (e.g. 21_06_2006)</li>
</ul>
<P>
For installation, run the install script with --help option:<br>
    <ul>
  <li>sh grass-6.2.cvs-ARCH-DD_MM_YYYY-install.sh --help  </li>
  or
  <li>./grass-6.2.cvs-ARCH-DD_MM_YYYY-install.sh --help  </li>
</ul><br>
Or without help, directly:<br>
    <ul>
  <li>sh grass-6.2.cvs-ARCH-DD_MM_YYYY-install.sh grass63-DD-MM-YYYY-arc-bin.tar.gz</li>
  or
  <li>./grass-6.2.cvs-ARCH-DD_MM_YYYY-install.sh grass63-DD-MM-YYYY-arc-bin.tar.gz</li>
</ul>
<h3>Libraries</h3>
The following libraries and programs are required:
<ul>
  <li>libpq (e.g. libpq3 or libpq4)  </li>
  <li>libproj (e.g. proj for Debian, libproj for Mandriva)  </li>
  <li>libgdal (e.g. libgdal1 for Debian, libgdal for Mandriva)  </li>
  <li>xterm</li>
</ul>
and, recommended, also:
<ul>
  <li>tcl (e.g.tcl8.3 or tcl8.4)</li>
  <li>tk (e.g. tk8.3 or tk8.4)</li>
  <li>gdal tools</li>
  <li>libfftw (fftw2, fftw3 or libfftw2, libfftw3)</li>
</ul>
<h3>NOTE:</h3>
In some distributions (e.g. Debian, Mandriva) the names of libraries are slightly different.
Check, and if there is no file of the name:<br>
libtk.so.0<br>
libtcl.so.0<br>
libpq.so.2<br>
libgdal.so.1<br>
libdfftw.so.2<br>
<br>
then you should type:<br><br>
    su<br>
    ln -s /usr/lib/libtk.so /usr/lib/libtk.so.0<br>
    ln -s /usr/lib/libtcl.so /usr/lib/libtcl.so.0<br>
    ln -s /usr/lib/libpq.so.3 /usr/lib/libpq.so.2<br>
    ln -s /usr/lib/libgdal.1.1.so /usr/lib/libgdal.so.1<br>
    ln -s /usr/lib/libfftw.so.2 /usr/lib/libdfftw.so.2<br>
    ldconfig<br>
<p>
As a first argument, you should put the names of the libraries you have in your distribution.<br>
Instead of (or in addition to) libtk.so and libtcl.so, you might have
libtk8.3.so and libtcl8.3.so (or libtk8.4.so and libtcl8.4.so). In this case, type instead:<br><br>
    ln -s /usr/lib/libtk8.3.so /usr/lib/libtk.so.0<br>
    ln -s /usr/lib/libtcl8.3.so /usr/lib/libtcl.so.0<br>
    ldconfig<br>
<h1>How to uninstall</h1>
sh /usr/local/bin/grass63uninstall.sh<br>
If it's not there, then:<br>
rm -rf /usr/local/bin/grass63<br>
rm -rf /usr/local/bin/grass63-DD-MM-YYYY<br>
rm -rf /usr/local/grass63-DD-MM-YYYY<br>
<P>
<hr>
This snapshot was configured as follows:
<pre>
CFLAGS="-O2" LDFLAGS="-s" ./configure \
  --with-libs=/usr/local/lib \
  --with-gdal=/usr/local/bin/gdal-config \
  --with-postgres-includes=/usr/include/pgsql --with-postgres-lib=/usr/lib \
  --with-mysql-includes=/usr/include/mysql --with-mysql-libs=/usr/lib/mysql \
  --with-fftw \
  --with-proj \
  --with-sqlite \
  --with-cxx \
  --with-motif \
  --with-motif-includes=/usr/X11R6/LessTif/Motif1.2/include \
  --with-motif-libs=/usr/X11R6/LessTif/Motif1.2/lib \
  --with-freetype --with-freetype-includes=/usr/include/freetype2 \
  --with-glw \
  --with-nls
</pre>
<hr>
Get this <a href=README.html>file.</a>
<p>
Please help us and report bugs.<br>
<a href=http://grass.itc.it/bugtracking/bugreport.html>Bug report form</a>
</body>
</html>
More information about the grass-web mailing list
