[GRASSweb-list]Fw: list GRASSLIST: List Message Rejected
Markus Neteler neteler at itc.it
Mon Jan 23 06:02:12 EST 2006
Lubica,
we can't do this for you (technically not possible).
Please *first* subscribe, then post:
 http://grass.itc.it/community/support.php#int_list
To subscribe to the GRASS Users List, send email to: listproc at baylor.edu
In the body of the message, write the command:
subscribe GRASSLIST [your e-mail address]
(don't use the []'s)
regards
On Sat, Jan 21, 2006 at 07:58:25PM +0100, Lubica Cverckova wrote:
> HI,
> I have trying to suscribe, but it does not seem to work, and I have been getting the rejection emails. Can you please suscribe me to the GRASS mailing list.
> Thank you.
> Lubica
> 	-----Pôvodná správa-----
> 	Od: [mailto:listproc at baylor.edu]
> 	Odoslané: 1. januára 0001 0:00
> 	Komu: cverckova at pobox.sk
> 	Predmet: list GRASSLIST: List Message Rejected
> 	Dear cverckova at pobox.sk:
> 	Your recent message to the GRASSLIST list has been
> 	rejected for the following reason:
> 	Only list subscribers may send messages to this list.
> 	If you need assistance, please contact the list owner at
> 	GRASSLIST-request at baylor.edu
> 	The text of your message follows:
> 	Received: from fs-exchange1.baylor.edu (sisko.baylor.edu [129.62.3.211])
> 	by ccis01.baylor.edu (8.9.3p2/8.9.1) with ESMTP id MAA1142856
> 	for <GRASSLIST at listproc.baylor.edu>; Sat, 21 Jan 2006 12:48:49 -0600 (CST)
> 	Received: from merle.baylor.edu ([129.62.3.143]) by fs-exchange1.baylor.edu with Microsoft SMTPSVC(6.0.3790.211);
> 	Received: from willie.baylor.edu ([129.62.8.12]) by merle.baylor.edu with Microsoft SMTPSVC(6.0.3790.1830);
> 	Received: from nudle.mail-atlas.net ([212.47.13.81])
> 	by willie.baylor.edu (SMSSMTP 4.0.5.66) with SMTP id M2006012112461312794
> 	for <GRASSLIST at baylor.edu>; Sat, 21 Jan 2006 12:46:14 -0600
> 	X-Spam-Status: No, hits=0.0 required=9.0
> 	tests=ALL_TRUSTED: -2.4,AWL: 0.810,PRIORITY_NO_NAME: 1.455,
> 	SARE_RECV_ADDR: 0.027,X_PRIORITY_HIGH: 0.125
> 	X-Spam-Level:
> 	Received: from NUDLE ([127.0.0.1])
> 	by nudle.mail-atlas.net
> 	for GRASSLIST at baylor.edu;
> 	Sat, 21 Jan 2006 19:46:10 +0100
> 	From: "Lubica Cverckova" <cverckova at pobox.sk>
> 	To: GRASSLIST at baylor.edu
> 	Message-ID: <798e7f323e9a4119abf6c29d5e8cdf07 at pobox.sk>
> 	Date: Sat, 21 Jan 2006 19:46:10 +0100
> 	X-Priority: 1 (Highest)
> 	Subject: data format (Linux - Windows)
> 	MIME-Version: 1.0
> 	Content-type: text/plain; charset=windows-1250
> 	X-OriginalArrivalTime: 21 Jan 2006 18:48:49.0370 (UTC) FILETIME=[5105F3A0:01C61EBB]
> 	Content-Transfer-Encoding: 8bit
> 	X-MIME-Autoconverted: from quoted-printable to 8bit by ccis01.baylor.edu id MAA1142949
> 	Hi,
> 	I have been working in school with GRASS on Linux machines. Now, I installed a Windows version of GRASS and I am trying to open the data that I worked with on Linux Grass, but it gives me an error that it is not a supported format. Now, I need only .dm or .dmrc data format. So, I tried to import a binary file, and it does not want to open it up either. Is there some converter that could convert Linux Grass data format into Windows Grass? Any help will be appreciated.
> 	Lubica
> 	Aktivujte si neobmedzenu mailovu schranku na www.pobox.sk!
Markus Neteler     <neteler itc it>       http://mpa.itc.it
ITC-irst -  Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18        -       38050 Povo (Trento), Italy
More information about the grass-web mailing list
