[GRASSweb-list]Fwd: list GRASSLIST: List Message Rejected
lists at nabble.com lists at nabble.com
Fri Jan 27 16:38:26 EST 2006
Hi, GRASS list owner:
I received the following rejection message from the
GRASSLIST at baylor.edu list. My address should be on the subscriber
list, is it recently removed? If so, could you please let me know why?
If this is by accident, should I re-subscribe? Please let me know if
you have any questions or concerns.
Regards,
Will L
Nabble.com
---------- Forwarded message ----------
From: listproc at baylor.edu <listproc at baylor.edu>
Date: Jan 27, 2006 1:12 PM
Subject: list GRASSLIST: List Message Rejected
To: lists at nabble.com
Cc: grass at baylor.edu
Dear lists at nabble.com:
Your recent message to the GRASSLIST list has been
rejected for the following reason:
Only list subscribers may send messages to this list.
If you need assistance, please contact the list owner at
GRASSLIST-request at baylor.edu
The text of your message follows:
Received: from fs-exchange1.baylor.edu (sisko.baylor.edu [129.62.3.211])
        by ccis01.baylor.edu (8.9.3p2/8.9.1) with ESMTP id PAA1389912
        for <GRASSLIST at listproc.baylor.edu>; Fri, 27 Jan 2006 15:12:26
-0600 (CST)
Received: from merle.baylor.edu ([129.62.3.143]) by
fs-exchange1.baylor.edu with Microsoft SMTPSVC(6.0.3790.211);
         Fri, 27 Jan 2006 15:12:25 -0600
Received: from willie.baylor.edu ([129.62.8.12]) by merle.baylor.edu
with Microsoft SMTPSVC(6.0.3790.1830);
         Fri, 27 Jan 2006 15:09:27 -0600
Received: from talk.nabble.com ([72.21.53.35])
 by willie.baylor.edu (SMSSMTP 4.0.5.66) with SMTP id M2006012715092804142
 for <grasslist at baylor.edu>; Fri, 27 Jan 2006 15:09:28 -0600
Received: from localhost ([127.0.0.1] helo=talk.nabble.com)
        by talk.nabble.com with esmtp (Exim 4.50)
        id 1F2aqT-0002fp-3u
        for grasslist at baylor.edu; Fri, 27 Jan 2006 13:09:25 -0800
Message-ID: <2626287.post at talk.nabble.com>
Date: Fri, 27 Jan 2006 13:09:25 -0800 (PST)
From: "endeitz (sent by Nabble.com)" <lists at nabble.com>
Reply-To: endeitz <endeitz at yahoo.com>
To: grasslist at baylor.edu
Subject: Re: r.terraflow failured
In-Reply-To: <be6d172050705111977c8fb0 at mail.gmail.com>
MIME-Version: 1.0
Content-Type: multipart/alternative;
        boundary="----=_Part_3110_22927288.1138396165113"
X-Nabble-Sender: Nabble Forums <lists at nabble.com>
X-Nabble-From: endeitz <endeitz at yahoo.com>
References: <42C98648.7010501 at deprem.gov.tr>
<be6d17205070412074893f122 at mail.gmail.com>
<42C9A9B3.7000603 at deprem.gov.tr>
<20050705180606.4b77a319.hamish_nospam at yahoo.com>
X-OriginalArrivalTime: 27 Jan 2006 21:09:27.0776 (UTC)
FILETIME=[F52F0600:01C62385]
------=_Part_3110_22927288.1138396165113
Content-Type: text/plain; charset=us-ascii
Content-Transfer-Encoding: 7bit
>From the thread history below, I surmised that the >2GB exception was
fixed.  However, when I use the latest snapshop binaries I still get
the error.  I have verified that my kernel supports large files by
creating several >2GB files.  Anyone have any advice?  I have pasted
the output below.
(using grass-6.1.cvs-i686-pc-linux-gnu-21_01_2006.tar.gz on Redhat 9.0)
GRASS 6.1.cvs (lcra):~/grassinstall > r.terraflow elev=test
filled=test_out direction=test_dir swatershed=test_shed
accumulation=test_acc tci=test_tci
r.terraflow December 2003
region size is 28458 x 28438
cell test header compatible with region header
elevation stored as FLOAT (4B)
STREAM temporary files in /var/tmp  (THESE INTERMEDIATE STREAMS WILL
NOT BE DELETED IN CASE OF ABNORMAL TERMINATION OF THE PROGRAM. TO SAVE
SPACE PLEASE DELETE THESE FILES MANUALLY!)
MFD flow direction
D8CUT=999999986991104.000000
memory size: 300.00M (314572800) bytes
Memory manager registering memory in MM_WARN_ON_MEMORY_EXCEEDED mode.
reading data from test to stream /var/tmp/STREAM_Ke0baI:    63%  File
size limit exceeded (core dumped)
GRASS 6.1.cvs (lcra):~/grassinstall > ls -lh /var/tmp/
total 2.1G
-rw-------    1 endeitz  endeitz      2.0G Jan 27 13:43 STREAM_Ke0baI
GRASS 6.1.cvs (lcra):~/grassinstall > dd if=/dev/zero of=testsize
bs=1024k count=3000
3000+0 records in
3000+0 records out
total 5.0G
-rw-r--r--    1 endeitz   endeitz      2.9G Jan 27 13:47 testsize
----------------------------------end output
Thanks,
Ed.
David Finlayson wrote:
> Thanks Laura.
> David
> On 7/5/05, Laura Toma  wrote:
>> I changed in  r.terraflow/IOStream/lib/src/Makefile
>> line9: CXX = g++ -Wall
>> to
>> CXX = g++ -Wall -D_FILE_OFFSET_BITS=64
>> Then I cleaned everything, and recompiled, and it works now for me (on
>> a Linux machine).
>> cd IOStream/lib/src/
>> make clean
>> make
>> cd ..
>> make
>> cd ../../
>> gmake
>> etc
>> > orkun wrote:
>> >> thank you
>> >> You are right.
>> >> that file made my disk full.
>> >> Although I used a small region for testing purposes. It produced
>> >> giantic files.
>> >> I do not know what will happen if I use whole region ?
>> The files produced  have a maxsize of 80N bytes, where N = nrows x
>> ncols of your grid.  They will be smaller, if your grid contains (a lot
>> of) nodata.  Check out the html page of r.terraflow for details.
>> As you run terraflow, the first lines will tell you what is the grid
>> size, and the max size of the temporary files.
>> How small was the region you tried it on?  To produce a file >2GB, you
>> must have used a grid larger than 3600x3600 cells.
>> Hope this helps,
>> Laura
> David Finlayson
> Marine Geology & Geophysics
> School of Oceanography
> Box 357940
> University of Washington
> Seattle, WA  98195-7940
> USA
> Office: Marine Sciences Building, Room 112
> Phone: (206) 616-9407
> Web: http://students.washington.edu/dfinlays
View this message in context:
http://www.nabble.com/-GRASSLIST%3A7445-r.terraflow-failured-t121508.html#a2626287
Sent from the Grass - Users forum at Nabble.com.
Content-Type: text/html; charset=us-ascii
>From the thread history below, I surmised that the &gt;2GB exception
was fixed. &nbsp;However, when I use the latest snapshop binaries I
still get the error. &nbsp;I have verified that my kernel supports
large files by creating several &gt;2GB files. &nbsp;Anyone have any
advice? &nbsp;I have pasted the output below.
<br>
<br>(using grass-6.1.cvs-i686-pc-linux-gnu-21_01_2006.tar.gz on Redhat 9.0)
<br>
<br>-----------------------------------------------
<br>GRASS 6.1.cvs (lcra):~/grassinstall &gt; r.terraflow elev=test
<br>r.terraflow December 2003
<br>region size is 28458 x 28438
<br>cell test header compatible with region header
<br>elevation stored as FLOAT (4B)
<br>STREAM temporary files in /var/tmp &nbsp;(THESE INTERMEDIATE
STREAMS WILL NOT BE DELETED IN CASE OF ABNORMAL TERMINATION OF THE
PROGRAM. TO SAVE SPACE PLEASE DELETE THESE FILES MANUALLY!)
<br>MFD flow direction
<br>D8CUT=999999986991104.000000
<br>memory size: 300.00M (314572800) bytes
<br>Memory manager registering memory in MM_WARN_ON_MEMORY_EXCEEDED mode.
<br>reading data from test to stream /var/tmp/STREAM_Ke0baI: &nbsp;
&nbsp;63% &nbsp;File size limit exceeded (core dumped)
<br>
<br>GRASS 6.1.cvs (lcra):~/grassinstall &gt; ls -lh /var/tmp/
<br>total 2.1G
<br>-rw------- &nbsp; &nbsp;1 endeitz &nbsp;endeitz &nbsp; &nbsp;
&nbsp;2.0G Jan 27 13:43 STREAM_Ke0baI
<br>
<br>GRASS 6.1.cvs (lcra):~/grassinstall &gt; dd if=/dev/zero
of=testsize bs=1024k count=3000
<br>3000+0 records in
<br>3000+0 records out
<br>
<br>total 5.0G
<br>-rw------- &nbsp; &nbsp;1 endeitz &nbsp; endeitz &nbsp; &nbsp;
<br>-rw-r--r-- &nbsp; &nbsp;1 endeitz &nbsp; endeitz &nbsp; &nbsp;
&nbsp;2.9G Jan 27 13:47 testsize
<br>
<br>----------------------------------end output
<br>
<br>Thanks,
<br>
<br>Ed.
<br>
<br>
<br>
<br><blockquote style="border-left: 2px solid #666666; border-top: 1px
solid #eeeeee; margin: 15px 20px;">
<div style="color: #333333; font: bold 11px
tahoma,geneva,helvetica,arial,sans-serif; padding: 5px 10px;">David
Finlayson wrote:</div>
<div style="color: #333333; font: 11px
tahoma,geneva,helvetica,arial,sans-serif; padding: 5px 10px;">Thanks
Laura.
<br>
<br>David
<br>
<br>On 7/5/05, Laura Toma &lt;ltoma at bowdoin.edu&gt; wrote:
<br>&gt; I changed in &nbsp;r.terraflow/IOStream/lib/src/Makefile
<br>&gt;
<br>&gt; line9: CXX = g++ -Wall
<br>&gt;
<br>&gt; to
<br>&gt;
<br>&gt; CXX = g++ -Wall -D_FILE_OFFSET_BITS=64
<br>&gt;
<br>&gt; Then I cleaned everything, and recompiled, and it works now for me (on
<br>&gt; a Linux machine).
<br>&gt;
<br>&gt; cd IOStream/lib/src/
<br>&gt; make clean
<br>&gt; make
<br>&gt; cd ..
<br>&gt; make
<br>&gt; cd ../../
<br>&gt; gmake
<br>&gt; etc
<br>&gt;
<br>&gt;
<br>&gt;
<br>&gt; &gt; orkun wrote:
<br>&gt; &gt;&gt; thank you
<br>&gt; &gt;&gt; You are right.
<br>&gt; &gt;&gt; that file made my disk full.
<br>&gt; &gt;&gt; Although I used a small region for testing purposes.
It produced
<br>&gt; &gt;&gt; giantic files.
<br>&gt; &gt;&gt; I do not know what will happen if I use whole region ?
<br>&gt; &gt;&gt;
<br>&gt;
<br>&gt;
<br>&gt; The files produced &nbsp;have a maxsize of 80N bytes, where N = nrows x
<br>&gt; ncols of your grid. &nbsp;They will be smaller, if your grid
contains (a lot
<br>&gt; of) nodata. &nbsp;Check out the html page of r.terraflow for details.
<br>&gt;
<br>&gt; As you run terraflow, the first lines will tell you what is the grid
<br>&gt; size, and the max size of the temporary files.
<br>&gt; How small was the region you tried it on? &nbsp;To produce a
file &gt;2GB, you
<br>&gt; must have used a grid larger than 3600x3600 cells.
<br>&gt;
<br>&gt; Hope this helps,
<br>&gt; Laura
<br>&gt;
<br>&gt;
<br>
<br>
<br>--
<br>David Finlayson
<br>Marine Geology & Geophysics
<br>School of Oceanography
<br>Box 357940
<br>University of Washington
<br>Seattle, WA &nbsp;98195-7940
<br>USA
<br>
<br>Office: Marine Sciences Building, Room 112
<br>Phone: (206) 616-9407
<br>Web: <a href="http://students.washington.edu/dfinlays"
target="_top" rel="nofollow">http://students.washington.edu/dfinlays</a>
</div>
</blockquote>
<br><hr align="left" width="300">
View this message in context: <a
href="http://www.nabble.com/-GRASSLIST%3A7445-r.terraflow-failured-t121508.html#a2626287">Re:
r.terraflow failured</a><br>
Sent from the <a
href="http://www.nabble.com/Grass---Users-f1202.html">Grass -
Users</a> forum at Nabble.com.
------=_Part_3110_22927288.1138396165113--
More information about the grass-web mailing list
