[GRASSweb-list] scott: web/bugtracking explain_new_tracker.inc, 1.4, 1.5
grass at intevation.de grass at intevation.de
Fri Feb 9 13:07:16 EST 2007
Author: scott
Update of /grassrepository/web/bugtracking
In directory doto:/tmp/cvs-serv30582
Modified Files:
Log Message:
remove version specificity and add spearfish download link
Index: explain_new_tracker.inc
RCS file: /grassrepository/web/bugtracking/explain_new_tracker.inc,v
retrieving revision 1.4
retrieving revision 1.5
diff -u -d -r1.4 -r1.5
--- explain_new_tracker.inc	9 Feb 2007 10:07:16 -0000	1.4
+++ explain_new_tracker.inc	9 Feb 2007 18:07:14 -0000	1.5
@@ -21,12 +21,11 @@
 Maciej Sieczka [tutey &lt;at&gt; o2 &lt;dot&gt; pl].</b>
 <p>
 Please consider the following when submitting bugs or feature requests:<ul>
-<li>Please only report bugs if using at least the current stable release version
-(GRASS 6.2.1 was released  12 Dec 2006), or later.
+<li>Please only report bugs if using at least the current stable release version.
 If you use an older version, please consider <a href="../download/index.php">upgrading</a>.
 <li> Make sure that the developers have all the information needed
         to recreate the bug
-     <BR>(e.g. explain how to reproduce the bug using the Spearfish example dataset).
+     <BR>(e.g. explain how to reproduce the bug using the <a href="../download/data6.php">Spearfish example dataset</a>).
 <li> Report only a single bug with each request.
 <li> Before reporting a bug, please check that it is currently unknown:
 <ul><li><a href="http://wald.intevation.org/search/advanced_search.php?group_id=21">New bug tracker search page</a>
More information about the grass-web mailing list
