[GRASSweb-list] hamish: web/announces announce_grass622.html, 1.7, 1.8
grass at intevation.de grass at intevation.de
Mon Jul 2 23:16:13 EDT 2007
Author: hamish
Update of /grassrepository/web/announces
In directory doto:/tmp/cvs-serv12157
Modified Files:
Log Message:
v.in.gpsbabel portability
Index: announce_grass622.html
RCS file: /grassrepository/web/announces/announce_grass622.html,v
retrieving revision 1.7
retrieving revision 1.8
diff -u -d -r1.7 -r1.8
--- announce_grass622.html	1 Jul 2007 22:26:43 -0000	1.7
+++ announce_grass622.html	3 Jul 2007 03:16:11 -0000	1.8
@@ -129,7 +129,8 @@
 <ul>
  <li> <b>DBMI/SQL parser</b>: Add missing TIME support
  <li> <b>DBF Driver</b>: Add missing SQL TIME support; fix semicolon problem
- <li> <b>Sqlite driver</b>: Add missing 'date' support; transactions to speed up 'execute'; SQLite: don't crash with SQLITE_NULL
+ <li> <b>Sqlite driver</b>: Add missing 'date' support;
+      transactions to speed up 'execute'; don't crash with SQLITE_NULL
  <li> <b>QGIS-GRASS DB bug</b>: Fixes QGIS <a href="https://svn.qgis.org/trac/ticket/448">bug #448</a>
  <li> <b>geodetic datum</b>: Enable geodetic datum for Krovak, fixed Slovakia Datum (hermannskogel)
  <li> <b>libgis</b>: Backport false easting/northing test
@@ -173,9 +174,10 @@
  <li> <b>v.build.polylines</b>: Build polylines out of a closed boundaries,
          remove doubled vertices at each node
  <li> <b>v.clean</b> snap tool: Remove doubled vertices
- <li> <b>v.dissolve</b>: Dissolve common boundaries by attribute; fix for DBMI error if input map is specified with @mapset
+ <li> <b>v.dissolve</b>: Dissolve common boundaries by attribute;
+      fix for DBMI error if input map is specified with @mapset
  <li> <b>v.in.ascii</b>: Skip over blank lines without error, improve robustness
- <li> <b>v.in.gpsbabel</b>: Attribute import fixed for tracks and routes
+ <li> <b>v.in.gpsbabel</b>: Attribute and point import fixed for tracks and routes; works with Mac OSX
  <li> <b>v.in.region</b>: Add additional vertex if necessary to ensure line
       segments don't exceed 180 degrees longitude and wrap the wrong way around the world
  <li> <b>v.lidar.*</b>: Various fixes backported
More information about the grass-web mailing list
