[GRASS-web] Slovakia mirror
Markus Neteler neteler at osgeo.org
Tue Mar 24 11:43:14 EDT 2009
Hello Pavol,
I have added your site to the list - will show up in circa 30min from now.
Thanks for hosting GRASS,
Markus
On Tue, Mar 24, 2009 at 8:43 AM, Pavol Cvengros
<pavol.cvengros at primeinteractive.net> wrote:
> Hello Markus,
> I have changed my rsync to mirror from grass.osgeo.org.
> Best regards,
> Pavol
> On 23. 3. 2009 21:51, Markus Neteler wrote:
>> Hello Pavol,
>> I see that http://grass.sk/index.php
>> is lagging behind for 3 days... maybe you need to read from
>> grass.osgeo.org?
>> The rsync server responds well.
>> Best regards,
>> Markus
>> On Sun, Mar 22, 2009 at 12:18 PM, Pavol Cvengros
>>> Hello,
>>> rsync server on my server is set. Only one repository available from sync
>>> and that is grass. Maximum 20 parallel connections.
>>> Please test it and if everything will be ok I would like to apply for
>>> tier 1
>>> mirror server.
>>> Rsync server: grass.sk
>>> Best regards,
>>> Pavol
>>> On 11. 3. 2009 9:22, Markus Neteler wrote:
>>> Hello Pavol,
>>> On Wed, Mar 11, 2009 at 7:48 AM, Pavol Cvengros
>>> Hello,
>>> I am running Slovakia mirror on my private server with courtesy of Prime
>>> Interactive Ltd. for a long time on domain grass.sk
>>> I found that you are looking for tier 1 mirrors. What is needed to become
>>> one? Is the only one condition to run rsync server to provide mirroring
>>> capabilities for tier 2 server?
>>> that's right! Just "be open", say, permit others to rsync from you.
>>> All this originates from the times that the master site was grass.itc.it
>>> with
>>> limited bandwiths. grass.osgeo.org is well connected (thanks to
>>> telascience.org)
>>> so that we reach 2.x TB (!) peaks per months.
>>> However, mirrors don't harm and we prefer a semi-decentralized
>>> infrastructure
>>> in case the North Atlantic or Pacific network bones get cut. Still we'd
>>> remain
>>> online :)
>>> If you have enough bandwidth you may enable others to rsync from you.
>>> Then please ping us here to update the mirror list (next of your mails
>>> will
>>> go through directly).
>>> Best regards,
>>> Markus
More information about the grass-web mailing list
