[GRASS-web] Fwd: [ibiblio.org #48154] grass.ibiblio.org is down / permission error
Scott Mitchell smlists at me.com
Fri Apr 22 06:46:25 EDT 2011
Thanks for testing, I'll send back the feedback.
Scott
On 2011-04-22, at 03:54 , Markus Neteler wrote:
> Also index.php should become the main file,
> http://mirrors.ibiblio.org/grass/download/
> Name	Last Modified	Size	Type
> Parent Directory/	 	-  	Directory
> addons.inc	2010-Jul-16 18:18:27	0.9K	application/octet-stream
> addons.php	2011-Mar-02 12:11:03	2.4K	application/octet-stream
> cdrom.inc	2010-Jul-19 12:11:03	3.6K	application/octet-stream
> cdrom.php	2011-Mar-02 12:11:03	2.4K	application/octet-stream
> data.inc	2010-Jul-16 18:18:27	1.6K	application/octet-stream
> --> it should show the index.php instead...
> Markus
> On Fri, Apr 22, 2011 at 9:52 AM, Markus Neteler <neteler at osgeo.org> wrote:
>> Also the redirect fails:
>> http://grass.ibiblio.org/download/index.php
>> 403 Forbidden
>> You don't have permission to access /download/index.php on this server.
>> On Fri, Apr 22, 2011 at 9:51 AM, Markus Neteler <neteler at osgeo.org> wrote:
>>> No strong opinion but the updating apparently fails...
>>> Markus
>>> On Thu, Apr 21, 2011 at 11:18 PM,  <smlists at mac.com> wrote:
>>>> Opinions?
>>>> (see below)
>>>> Begin forwarded message:
>>>> From: "Justin via RT" <help at rt.ibiblio.org>
>>>> Date: 21 April, 2011 14:40:08 EDT
>>>> To: smitch at spamcop.net
>>>> Cc: chuck at ibiblio.org, cmpalmer at metalab.unc.edu, ebailey at ibiblio.org,
>>>> elrahals at ibiblio.org, ethan_kromhout at unc.edu, john at ibiblio.org,
>>>> johnwood at email.unc.edu, pjones at ibiblio.org, styonsk at ibiblio.org
>>>> Subject: [ibiblio.org #48154] grass.ibiblio.org is down / permission error
>>>> Reply-To: help at rt.ibiblio.org
>>>> Hi Scott,
>>>> Thanks for your patience on this: I have an update for you.
>>>> I've moved the grass mirror to http://mirrors.ibiblio.org/grass/ - php
>>>> is working.  I've configured the mirror to update daily at 5:30am.
>>>> We'd like to set up a 301 redirect for grass.ibiblio.org that will
>>>> expire in 3 or so months.  We've found that is enough time for search
>>>> engines and the like to update to the new address.  Would this work for
>>>> your project?
>>>> Justin
> grass-web mailing list
> grass-web at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-web
More information about the grass-web mailing list
