[GRASS-web] Error bug d.rast
Markus Neteler neteler at osgeo.org
Fri Jan 10 11:17:40 PST 2014
(please keep the conversation on the list)
Do you use the graphical user interface and then the error comes up?
Regards
Markus Neteler
On Fri, Jan 10, 2014 at 8:13 PM, Carmine Massarelli
<c.massarelli at gmail.com> wrote:
> Hello,
> i have used both windows 7 and 8.1.
> The error is d.rast map=.... failed.
> The problem could be linked to wxphyton.
> Best reguards
> Carmine Massarelli PhD
> Il giorno 10/gen/2014 20:09, "Markus Neteler" <neteler at osgeo.org> ha
> scritto:
>> On Fri, Jan 10, 2014 at 7:47 PM, Carmine Massarelli
>> > Hello,
>> > I want only to advice you that the last version of Grass 6.4.2.
>> > (downloaded
>> > with Qgis for 64-bit system) does not function. The module d.rast goes
>> > in
>> > crash and it is not possible to visualize the map. The error is not in
>> > the
>> > same version for 32-bit system.
>> Please let us know which operating system are you using here.
>> Ideally, also send the error message.
>> BTW: The latest version is GRASS GIS 6.4.3.
>> Best regards
>> Markus Neteler
>> http://courses.neteler.org/blog/
More information about the grass-web mailing list
