[GRASS-web] Need Assistance
Markus Neteler neteler at osgeo.org
Mon May 12 12:00:09 PDT 2014
Hi Rushil​
you can achieve this in GRASS 6 by also adding the path to the start script
as a parameter. Then it will start the session right away:
Something like:
grass643 C:\Users\ru281187\Documents\grassdata\demolocation\PERMANENT
Other option: in GRASS GIS 7 this text menu no longer exists (only a
graphical user interface), so in -text mode GRASS will load the
location/mapset from the last session.
hope this helps
Markus
URL: <http://lists.osgeo.org/pipermail/grass-web/attachments/20140512/64cab22a/attachment.html>
More information about the grass-web mailing list
