[winGRASS] Terminal Error
Andreas Lange Andreas.Lange at Rhein-Main.de
Wed Aug 22 04:49:17 EDT 2001
Hi Taravudh,
this is a problem of your XFree86 installation for xterm IMHO.
A quick fix is to type
export TERM=vt100
before you start grass5.
I have currently the same problem and will look if i find a solution.
Does someone know what the correct terminal for the xterm under cygwin
is?
Andreas
Taravudh Tipdecho wrote:
> Hi all,
> According to instruction, I installed Cygwin/XFree86 running on
> Windows2000. Anyway, it was a problem from displaying which was "Error
> opening terminal:xterm. Invalid resource file, removing
> /home/taravudh/.grassrc5.  This dialog is come after Grass welcome
> message.
> Could you please give me some hints?
> Thanks.
> Taravudh Tipdecho
> winGRASS mailing list
> winGRASS at grass.itc.it
> http://grass.itc.it/mailman/listinfo/wingrass
Andreas Lange, 65187 Wiesbaden, Germany, Tel. +49 611 807850
url: http://mitglied.tripod.de/AndreasLange
mail: Andreas.Lange_at_Rhein-Main.de - A.C.Lange_at_GMX.net
More information about the grass-windows mailing list
