[winGRASS] libG11
Malcolm Blue mblue at nb.sympatico.ca
Tue Oct 2 07:39:49 EDT 2001
> -----Original Message-----
> From: wingrass-admin at grass.itc.it [mailto:wingrass-admin at grass.itc.it]On
> Behalf Of Mike Thomas
> PART 1 - Making libW11
> I don't know what the CVS structure is, but assuming there is a directory
> called "windows/libW11" somewhere in the XDRIVER tree, change directory
> there.
> Then type:
>     make clean
>     make
>     cp lib/libG11.dll /bin
Mike,  here use make install.  If you switch to new version remember to
clean out old libG11.dll from /bin.  This installs to /usr/local/bin.
> PART 2 - Modifying the head.i686-pc-cygwin file to define __W98__
> and to set
> the include path and library details:
> COMPILE_FLAGS       = -O -D__W98__
> XCFLAGS
> -I/grass/src/display/devices/XDRIVER/XDRIVER24/windows/libW11
> XLIBPATH
> -L/grass/src/display/devices/XDRIVER/XDRIVER24/windows/libW11/lib
> XTLIBPATH           =
> XMLIBPATH           =
> XLIB                = -lX11
Note that windows/libW11 is under devices:
XCFLAGS= -I/grass/src/display/devices/windows/libW11
XLIBPATH= -I/grass/src/display/devices/windows/libW11/lib
> PART 3 - Rebuilding "display/devices", "d.mon" etc
> Delete the "obj.i686-pc-cygwin" .o files in "devices/lib" and
> "XDRIVER" and
> "d.scale" directories and rebuild with gmake5.  The aim here is to ensure
> that no remaining object files were compiled with XFree86 headers and
> libraries - I may have forgotten some directories - safest to redo
> everything.
devices/lib doesn't use X.  It is linked into XDRIVER.
The other day after downloading into a new directory, I did the above steps
before compiling grass (between ./configure and make).  It worked fine.
BTW.  Since libG11 is a .dll, it is OK to just recompile the libG11.dll on
minor changes to libG11, i.e. as long as entry points in the .dll don't
change.  If in doubt, recompile XDRIVER too.
Regards,
Malcolm
Outgoing mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.281 / Virus Database: 149 - Release Date: 9/18/2001
More information about the grass-windows mailing list
