[GRASS5] [miketh@brisbane.paradigmgeo.com: [winGRASS] More info on libW11]
Glynn Clements glynn.clements at virgin.net
Tue Sep 11 11:14:28 EDT 2001
Markus Neteler wrote:
> "X11/Xos.h" is not present (comes in via "includes.h", don't know what this
> one is used for - commented out)
Xos.h is meant as a portable way to get various system definitions. We
should probably try to do without it, and handle any portability
issues ourselves.
> These functions are missing at link time and from the headers:
> XAllocSizeHints
> XAllocWMHints
> XAllocClassHint
> XGetWMName
> XSetWMName
You can do without these if you define "X11R3".
> XSetWindowColormap
Used to switch between the "fixed" and "float" colour modes. Probably
only needed if using "float" mode on a paletted display.
> XFreeColormap
Only called for DirectColor visuals, which probably don't exist in
W11.
> BlackPixel
> WhitePixel
These are mainly used to set the default background and foreground,
and aren't too important. The way that they are used in
Get_w_{box,line}.c is bogus, and should probably be changed.
> ConnectionNumber
This is used by Get_Xevent(), which would need to be re-implemented.
> XGetGCValues
This is only called with a valuemask of GCForeground, so a substitute
would only actually need to retrieve the selected foreground colour
(according to the most recent call to XSetForeground
The remainder should be able to be replaced by stubs.
Glynn Clements <glynn.clements at virgin.net>
More information about the grass-windows mailing list
