[winGRASS] Re: generic Windows GRASS driver
Malcolm Blue mblue at nb.sympatico.ca
Thu Sep 20 13:45:32 EDT 2001
Mike,
I'm writing this from memory, without the revised source that I had used on
hand, so excuse me if I'm a bit vague.
The XDriver window shuts down due to a call that creates the window (I think
in Graph_Set.c - XOpenDisplay(NULL) - but without my revisions handy, I
can't be sure).  The fix that I recall was to change the NULL (i.e. 0) to a
Null String "".
I'll try to find my version of the changes, but hopefully this hint can help
you fix this, if I can't locate it quickly.  You should still kill the
parent (I assume you are working on winNT or Win2K).
HTH,
Malcolm
-----Original Message-----
From: wingrass-admin at grass.itc.it [mailto:wingrass-admin at grass.itc.it]On
Behalf Of Mike Thomas
Sent: Thursday, September 20, 2001 5:10 AM
To: wingrass at grass.itc.it
Cc: Roberto Flor
Subject: [winGRASS] Re: generic Windows GRASS driver
Hi all.
Debugging the libW11 version of the XDriver - the exposition of my logic may
be a little laborious, but I am coming to grips with the differences between
X11 and Windows from behind the pole position.
OK - further to the report below, it seems that the libW11 display window
closes down as soon as the parent XDRIVER exits - that is, when the message:
    Graphics driver [x0] started - exiting
appears.
My interpretation of this is that the new window is not running as a
separate process and therefore is doomed to die with the process that
launches it (ie the parent XDriver).
I assume that this is not the case with X11 - that is, that the window is
under the control of the XServer rather than the XDriver and is therefore
preserved.
On this basis I used the __W98__ define to stop the parent from exiting.
This buys a display which waits for a response (looping on do_work(0)).
Calling d.erase causes the display to die.  Unfortunately the debugging
output messages keep on coming, without any visible parent process!!!
I'll worry about that tomorrow.
Cheers
Mike Thomas.
----- Original Message -----
From: Mike Thomas <miketh at brisbane.paradigmgeo.com>
To: Glynn Clements <glynn.clements at virgin.net>; Markus Neteler
<neteler at itc.it>
Cc: Roberto Flor <flor at itc.it>
Sent: Thursday, September 20, 2001 5:23 PM
Subject: Re: generic Windows GRASS driver
> Hi there.
> > > So, the idea to test is to change the ConnectionNumber(dpy)
> > > to XConnectionNumber(dpy) in Xdriver/Serve_Xevent.c.
> Unfortunately it didn't work - but thanks for the input.
> I think I'm going to have to delve further into the meaning of those
> messages in the debug printout returned by get_command eg:
> DRIVER main: before get_command
> DRIVER main: before process_command c = K
> DRIVER main: before Do_work(1)
> I really want to use gdb to find out exactly when the display disappears,
> but although it attaches to an already running XServer it insists on
> starting a new process.  I end up with two XDrivers and the one being
traced
> by the debugger dies when it tries to get a connection.  Then the debugger
> and the terminal sessions bind up and refuse to shutdown.  Very
frustrating.
> I might try inserting a buch of sleep()s at strategic points to slow
> execution down and to catch the window closure point.
> Cheers
> Mike Thomas.
winGRASS mailing list
winGRASS at grass.itc.it
http://grass.itc.it/mailman/listinfo/wingrass
Incoming mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.265 / Virus Database: 137 - Release Date: 7/18/2001
Outgoing mail is certified Virus Free.
Version: 6.0.281 / Virus Database: 149 - Release Date: 9/18/2001
More information about the grass-windows mailing list
