[winGRASS] Re: generic Windows GRASS driver
Malcolm Blue mblue at nb.sympatico.ca
Fri Sep 21 16:26:04 EDT 2001
> -----Original Message-----
> From: Glynn Clements [mailto:glynn.clements at virgin.net]
> Mike Thomas wrote:
> > > Yes, XOpenDisplay(NULL) fails in the ntXlib that Mike is
> trying to use.
> > Sure does - I patched it to use a dummy string in the event that the
> > argument is NULL - an empty string is a better solution.
> Well, I'm looking at it from the perspective of reducing the amount of
> code which is conditionalised upon "#ifdef __W98__" or similar. So,
> personally I'd favour fixing libW11, even if that means providing our
> own version.
I agree, but I would like to see if we can get the last few display problems
resolved first.  I would like to use as much common code for the supported
grass platforms as possible.  Conditionalized code just means additional
maintenance effort.
This particular problem should be easy to fix in libW11.
Malcolm
> Glynn Clements <glynn.clements at virgin.net>
> Incoming mail is certified Virus Free.
> Checked by AVG anti-virus system (http://www.grisoft.com).
> Version: 6.0.281 / Virus Database: 149 - Release Date: 9/18/2001
Outgoing mail is certified Virus Free.
More information about the grass-windows mailing list
