[winGRASS] Re: libW11 - CVS loose ends and events
Markus Neteler neteler at itc.it
Fri Sep 28 03:35:32 EDT 2001
On Fri, Sep 28, 2001 at 02:39:57AM -0300, Malcolm Blue wrote:
> > -----Original Message-----
> > From: Mike Thomas [mailto:miketh at brisbane.paradigmgeo.com]
> > Sent: Friday, September 28, 2001 12:46 AM
> > You're right - I've now changed this around to match.  I look forward to
> > sorting out CVS.
> I'm attaching my changes from tonight.  This includes the changes to make
> libG11.dll, the change to Xos.h, replaced your calls to FreeBrushHandler
> with DeleteObject (we can just delete it without the tests, no harm), added
> XSetWMName, added XGetWMName, fixed XSetWMProperties to use the name
> property for the window, fixed XOpenDisplay to set the name properly, fixed
> XMapWindow to use the name in the window title bar, changed the display
> class to TrueColor so that XDRIVER doesn't fool around with color tables
> when it doesn't have to (plus it tells me I have over 16 million colors
> instead of a puny 256 - MORE COLORS!!) and a couple of other little
> cleanups.
thanks for sending, the code is in CVS now.
So far I didn't find the time to test, sorry (was busy with other stuff).
Happy hacking and a nice weekend,
 Markus
More information about the grass-windows mailing list
