[winGRASS] GRASS/R interface running also on winGRASS
Markus Neteler neteler at itc.it
Wed Apr 3 10:45:18 EST 2002
On Sat, Mar 30, 2002 at 01:30:57AM +0900, Hisaji ONO wrote:
> Hello.
>  Is this  GRASS/R interfac available in binaries?
... it is R code and available. Have a look here:
 http://grass.itc.it/statsgrass/index.html
Best regards
 Markus Neteler
> > if anyone is interested - we can announce that the GRASS/R
> > interface is also running in the following environment:
> >  - winGRASS with generic driver (no Xserver needed)
> >  - R for windows
> >  - GRASS/R interface
> >  - emacs
> >  - ESS (emacs speaks statistics user interface).
> > You will install all of above, then run emacs and/or R within GRASS (as on
> > Linux) and go to work. Just ignore the strange error messages which
> > are generated by the GRASS/R interface as no piping
> >  2> &1 > /dev/null
> > is available on Cygwin and no device /dev/null exists there.
> winGRASS mailing list
> winGRASS at grass.itc.it
> http://grass.itc.it/mailman/listinfo/wingrass
Markus Neteler
ITC-irst, Istituto per la Ricerca Scientifica e Tecnologica
     Project on Predictive Models for the Environment
Via Sommarive, 18        -      38050 Povo (Trento), Italia
tel +39 0461 314 -520 (fax -591)          http://mpa.itc.it
More information about the grass-windows mailing list
