[winGRASS] Installation Problems
Glynn Clements
glynn.clements at virgin.net
Wed Apr 24 08:47:47 EDT 2002
Kirk Schmidt wrote:
> I have been diligently working through the installation of grass5 for
> cygwin on a windows system (actually windows 98) I ran into a couple of
> minor snags with the install shell but that seems to have been overcome
> (a problem with the filesize checker). I have installed cygwin and it is
> operating as well. I also installed the evaluation version of Star Net
> Xwin-32 and it appears to work OK.
> When I activate cygwin and type in "grass5 help" I get the help
> standard help files which originate from the file file
> cygwin/usr/local/bin/grass5.sh
> This indicates that all is well.
> When I enter "grass5 -tcltk" i get the following message:
> usage: /usr/local/grass5/etc/lock file pid
> unable to properly access /home/Kirk Schmidt/.gislock5
> Upon checking the path to /home/Kirk Schmidt/ I only find a BASH
> history file
> Does anybody have any idea what the problem is?
The problem is that GRASS can't handle spaces in file names. You will
need to convince Cygwin to use a different value for your username and
home directory.
Glynn Clements <glynn.clements at virgin.net>
More information about the grass-windows
