[winGRASS] winGRASS install failure
Lorenzo Sandini lorenzo.sandini at uku.fi
Mon Jan 7 09:03:29 EST 2002
I just susbscribed to the list so I don't know if I can join a previous
thread, but I have exactly the same problem as Jean-Baptise Henry.
I checked the presence of find, gunzip and tar, all are present in the /bin
directory...
What do you mean "You should avoid to download with MS IE, as IE breaks the
binary format. " ?
What should I use to retrieve the file, since the link is given as an http
address ?
http://grass.itc.it/grass5/binary/windows_cygnus/grass5.0.0pre2_i686-pc-cygw
in_bin.tar.gz
I'll try a few links on FTP servers later...
Cygwin build is 1-3-6-6
Any help very much appreciated.
Lorenzo Sandini
Kirurgian Klinikka
Kansanterveyden Tutkimuslaitos
Kuopion Yliopisto
70200 Kuopio
SUOMI-FINLAND
+358.17.162.946
+358.17.162.940 (FAX)
http://kotisivu.raketti.net/brokenbone/erik
GSM-050.359.28.31
Hi Jean,
Jean Baptiste HENRY wrote:
> Dear list,
> I am a new user of Cygwin and Grass. I have tryed to install it on my
> Win 2k PC, but I systematically get error. I have strictly followed
> instructions, given on the binary install page. Here is what I get in
> the command line :
> $ ./grass5install.sh grass5.0.0pre2_i686-pc-cygwin_bin.tar.gz
> GRASS GIS 5 binary package installation tool
> Checking and creating installation directory...
> file: not found
> ERROR: You need the GRASS binary package in .tar.gz compression
> or bz2.
> I do not understand the error message. Thank you in advance for any piece
of advice.
> Sincerely yours.
I don't understand the error message too.
But could you open a cygwin terminal and check if the following programs
are found:
find
gunzip
tar
Perhaps your cygwin installation is broken. Which version do you use
(cygcheck)?
Is the binary package in the correct format? What does
file grass5.0.0*
say?
You should avoid to download with MS IE, as IE breaks the binary format.
HTH,
Andreas
Andreas Lange, 65187 Wiesbaden, Germany, Tel. +49 611 807850
url: http://mitglied.tripod.de/AndreasLange
mail: Andreas.Lange_at_Rhein-Main.de - A.C.Lange_at_GMX.net
Lorenzo Sandini
Kirurgian Klinikka
Kuopion Yliopisto
70200 Kuopio
SUOMI-FINLAND
+358.17.162.946
GSM-050.359.28.31
More information about the grass-windows mailing list
