[winGRASS] problems with tcltkgrass
Glynn Clements glynn.clements at virgin.net
Fri Aug 8 07:39:27 EDT 2003
grass at karsten-lessing.de wrote:
> My PC is running under Win2000 and I have some problems with tcltkgrass:
> Definitively I installed the whole package of cygwin which I´ve got
> from:
> http://xfree86.cygwin.com/
> so also xFree86 und X11R6.4 should be came with it !
Note: Cygwin's Tcl/Tk package doesn't work with GRASS. You need to use
the xtcltk package from the GRASS website (it should be on the same
page as the Cygwin binary packages).
> To start GRASS with tcltk I do the following:
> start Cygwin as described under:
> http://grass.baylor.edu/grass5/binary/windows_cygnus/cygwin_grass50bininstall.html
> In the appearing terminal I type in:
> "startxwin.bat"
I wouldn't recommend using that batch file; it isn't very reliable.
Just start the X server manually, using the XFree86 startx script.
Then start GRASS from an xterm.
Glynn Clements <glynn.clements at virgin.net>
More information about the grass-windows mailing list
