[winGRASS] d.mon/fifo problems
Malcolm Blue mblue at nb.sympatico.ca
Wed Jan 8 03:54:01 EST 2003
Hello,
The newer versions of Grass use sockets by default, instead of the old
fifo method.  This has been shown to be more compatible with the newer
OS's used by Grass users.  To use this method you don't have to specify
anything extra on the configure or compile command lines. ( to use fifo
requires external routines/libraries, which are available but probably
not tested with recent version of Grass.)
If you used the default compile method, you should have d.mon working.
I still get the following message in my compile log file:
"mkfifo: cannot create fifo ``/grass/dist.i686-pc-cygwin/dev/fifo.tmp'':
Function not implemented"
But this is not relevant since sockets have been supported.  The d.mon
commands still work.
If you have trouble starting a monitor using d.mon using the default
compile, then I think we need to check further.  What happens when you
use 'd.mon start=x0' at the grass prompt?
Cheers,
Malcolm
> -----Original Message-----
> From: wingrass-admin at grass.itc.it
> [mailto:wingrass-admin at grass.itc.it] On Behalf Of Jaro Hofierka
> Sent: January 3, 2003 3:54 AM
> To: wingrass at grass.itc.it
> Subject: [winGRASS] d.mon/fifo problems
> Hi,
> I'm having problems installing GRASS5.0.0 on cygwin/W2000
> Professional. I compiled the source code and everything went
> OK except for fifo creation in dev directory. Apparently
> mknod and mkfifo commands do not work properly in cygwin (at
> least in my release) - I am getting message "Function is not
> implemented". Can you advise me how to start d.mon monitor
> now? NVIZ works fine, though rather slow. But for simple and
> quick visualization I would need d.mon as well.
> Thanks for any hints!
> Jaro
> winGRASS mailing list
> winGRASS at grass.itc.it http://grass.itc.it/mailman/listinfo/wingrass
More information about the grass-windows mailing list
