[winGRASS] TCLTK repeat message as list member
Ian Allan iallan at geocode.com.au
Sat Mar 1 02:05:31 EST 2003
Hi
Under win 2000, I have installed cygwin, xfree 86, sunrpc & grass as per
the instructions (ticking each item as ive finished it).
I can login using the "--bash login -i" instruction & start grass using
usr/local/bin/grass. I can even type tcltkgrass& to get tcltkgrass to
start.
My problem is that when I display a monitor, TCLTK freezes & i cannot
select any further options from the tcltk grass menu.The only hint i
have about what the problem might be is that instructions were to
"ensure the official cygwin tcltk package was not installed" & then
install the tcltk stuff from the grass site. I assumed the official
tcltk was not installed because under the cygwin setup program I could
not see tcltk. Did i look in the right spot? I unpacked the xtcltk* file
as instructed anyhow.  Any ideas?
Many thanks
Ian Allan
PS. I have tried to get around the problem by downloading the wingrass
generic file, but every version i download seems to be corrupt
Type: text/x-vcard
Desc: Card for Ian Allan
Url : http://lists.osgeo.org/pipermail/grass-windows/attachments/20030301/e1f5f077/iallan.vcf
More information about the grass-windows mailing list
